Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 19-03-2015, 19:28
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
RoboRIO Teleop Freezeup
Howdy all! Working through a infrequently-occurring issue on our roboRIO:
A few times while connected to a field management system, we've had the RIO partially freeze up. We're still trying to gather telemetry to see what's happening exactly, but the symptoms are that the motors lock in at a single value (causing unwanted rotation we have to e-stop to prevent).
What we're observing via the driver station is a bump in processor load from 50% to 70%, and the RIO (but not the driver station) drops out of teleop mode.
There's no loops in this part of our code that would cause it to lock up. When it was happening, we were writing to a text log file on the RIO. Additonally, we read data from our sensors in separate threads from the main robot code. Other than that, it's just simple if statements and math.
We're already in the process of re-flashing the RIO firmware. It's hard to debug anything else since we can't reliably trigger the behavior yet. We're a bit worried there might be some corner-case in the RTOS we're hitting every now and then....
Anyone else observed similar odd behavior in the RIO?
Thanks much!
EDIT: Attached is a picture of our driver station log we captured during the anomaly.
Unread 21-03-2015, 11:37
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: RoboRIO Teleop Freezeup
My team has lost comms with the RIO after autonomous mode ran because of IP address assigned manually. I've never seen your issue before, but checking to make sure that the IP address is automatically assigned. Has re-imaging the RIO helped at all?
Unread 21-03-2015, 15:26
Altainia Altainia is offline
That one geeky guy...
FRC #5098 (Sting-R)
Altainia will become famous soon enoughAltainia will become famous soon enough
I'd be curious to see your code for writing to a text file since you say that's occurring when you lock up, as well as the code that's around that (context is important). Also, I'd like to see the code that's locking up.
I'm also curious: does the text file get successfully written?
Unread 23-03-2015, 23:32
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
If it's writing to the file on the main thread, then that would cause some freezing. Try creating a new thread to use only for file I/O.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 24-03-2015, 12:09
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
If your doing any form of file io, I would reccamend using network tables and logging all the data on the driverstation computer. If you need help with it pm me.
