Go to Post Watch out world, FIRST is going to become mainstream! - Church [more]
Unread 20-03-2015, 09:01
Dan5190 Dan5190 is offline
FRC #5190
Dan5190 is an unknown quantity at this point
USB Camera using too much bandwidth
Were using the Microsoft life cam camera with java and the smartdashboard. Were at the nc regionals and the fms crew is telling us the camera is using too much bandwidth. It spikes to 17mb/s when the camera first turns on and takes down the fms system for a few seconds then settles down to 3-4 mb/s but we still get a lot of dropped packets. Here is the code we are using on the robot.
CameraServer camera = CameraServer.getInstance();
camera.setQuality(25);
camera.setSize(1);
camera.startAutomaticCapture("cam0");
Unread 20-03-2015, 11:16
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: USB Camera using too much bandwidth
camera.setSize(1);
Is it possible to configure the camera so that its power on state is low bandwidth settings?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 20-03-2015, 12:21
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
We had this issue at Dallas. No settings in our Java code affected the amount of data. We had to switch to the Default Dashboard and use the pull down options to turn down the resolution, down the frame rate, and turn up the compression.
Unread 21-03-2015, 00:53
The SmartDashboard will override the size setting in your code, and defaults to 640x480. You can change it in the properties, although it appears it doesn't save the setting.
Unread 02-04-2015, 20:32
makahn64 makahn64 is offline
FRC #0256
makahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these parts
We just got told we weren't allowed to use the Microsoft camera at all over the network @ SVR. Maybe would have been nice to discover this problem before it was given out in the kit of parts...
Unread 02-04-2015, 22:58
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
What was the specific reason given?
Unread 03-04-2015, 13:30
FRC #0256
It was taking down the field control system because of using too much bandwidth. I don't believe we were given the option of experimenting with lower resolutions, though our programmer thinks it was already on the lowest. Honestly, with the tight schedules of these events, banning it outright was the right move.
I did find out it was not in the KOP, just a recommended product. But we cannot recommend it at all for a driving feed. We ended up borrowing an Axis camera.
Unread 09-04-2015, 18:14
tomasuciu tomasuciu is offline
FRC #1796 (RoboTigers)
tomasuciu has a spectacular aura abouttomasuciu has a spectacular aura about
A team at LI regional appeared the have the same problem, although they had their visual settings down to a point where it was unbearable. Not sure if this plausible, but different wireless cards on different laptops might be the issue (I'm thinking the way they intercept and process packets and data is different in terns of bandwidth usage?). Another explanation is that background tasks could be consuming bandwidth.
Unread 10-04-2015, 05:46
The amount of data that a compressed image will take is not dependent on the wifi card. The dashboard and field monitor report megabits of data usage. What were the numbers? Or what were the camera settings?
Greg McKaskle
Unread 10-04-2015, 10:24
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
One team at Northeastern had a similar issue, so there is some anecdotal evidence that the Microsoft LifeCam does not play as nicely as the Axis camera in the competition environment.
no stranger to the working end of a pencil
Unread 12-04-2015, 11:33
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
No, that means the WPILib code to stream camera data is not as reliable/bandwidth friendly as the Axis camera streaming code.
My evidence? We used mjpg-streamer to stream *2* simulataneous Lifecam camera feeds (each was 160x120, 10fps, 30% compression -- but we resized the images to a much larger resolution so our drivers could see it, works surprisingly well) from our robot to our dashboard at our regional, and to my knowledge did not receive any bandwidth complaints from the field.
