Thread Tools |
Rating:
Display Modes |
Teams scoring vast majority of points
I was joking with some students that Recycle Rush is a good model of the US Economic system, where a small percentage of participants control a vast majority of the wealth... but maybe its not a joke.
Has anyone looked at what % of teams score 80% of the points? Is there a way to easily looks at how many total points team XXXX scored at an event compared to the total points scored at that event? At the LA Regional, Team 330, Team 1197, and Team 973 seemed to overshadow the scoring of the other 63 teams. Maybe they didn't score 80% of all points scored, but it was quite a bit. Challenge: calculate, for each regional, what percent of ALL points scored were scored by the top 3 SCORING teams. (this is not just top three ranked by average score, but top three individual scorers.) Last edited by SenorZ : 03-20-2015 at 03:20 PM. Reason: mistake... put 987 orginally, not 973. Sorry 973!!! |
Re: Teams scoring vast majority of points
I would absolutely love to see this (and I have a hunch that you're right), but this requires data beyond what's available through FIRST. We'd need to find at least one team per event (preferably more) that has team-level data for every match, then go from there.
Actually, now that I think about it, maybe the good people behind frcscout.com could make this happen - they've got a lot of data in a standardized format. |
You could try it with OPR. Not perfect, but might be interesting anyway. Insert usual caveats about OPR.
I would suggest OPR as well. It's the best way we have so far to tease out each teams' individual contributions without actually watching every match.
I decided to do some quick analysis with QA data from weeks 1 - 3 since I had it (and didn't have OPR):
It's actually not as unevenly distributed as I expected. I'm guessing the fact that QAs are averaged, and therefore top teams can get pulled down by lower scoring partners and vice versa plays a role. It'll definitely be interesting to see how OPR works out. Notes: "top" and "bottom" just refer to the highest and lowest QAs, not to any other aspects of those teams. Percentages for the first two statistics are rounded to the nearest 0.5% |
Yeah, looking at QA or OPR is pretty much all that can be done, unless someone is taking perfect scouting data at an event.
Looking up FRCScout.com there are some errors (330 has zero points listed for some matches that definitely weren't zero). Maybe I'll try to get this hooked up for the new Ventura Regional next week. Should be some heavy hitters outscoring a majority of teams. |
#7
it's kinda this way every year...
#8
% of OPR sum vs % of Teams for weeks 1 thru 3 Match Results data
#9
Maybe I'm not "getting" this graph. It seems to show that as you include all teams in the OPR sum, you get the total OPR sum...
#10
... and that's what the plot shows (based on OPR, as suggested by previous posters) On the Y axis look for 80%. Trace horizontally from there until you hit the red line, then go straight down. The answer is 80% of the total OPR is due to 47% of the teams. Last edited by Ether : 03-20-2015 at 05:54 PM. |
#11
It's interesting to see a cumulative distribution go above 100% then decline!
I understand why that's happening (due to negative OPR) but it does underpin that OPR can be an odd beast. |
#12
Not sure OPR is necessarily the best metric to use here given that all teams from an alliance benefit from an individual's good performance. Alliances make the individual harder to judge (a team only capable of "capping" stacks with bins but not producing their own will only score well when teamed with a robot that can make large stacks, for instance). OPR is negative for some teams, while points scored cannot be negative (except for penalties). In other words, I feel the actual scoring potential of the best teams (the 1%) do produce more disparity than the 99% compared to Ether's graph. But without more specific data this is not too knowable. |
#13
#14
Calculate an "effective QA" for each team by: - For each match, sum up the final QA result of all teams in the alliance - For each team in the alliance, their personal contribution is estimated as a percentage of their alliance's score proportional to the sum of the alliance team's original QA - Calculate effective individual QA by averaging all matches in their competition (to normalize and account for different # of matches played at different events) For example: Team 1 QA = 95 Team 2 QA = 38 Team 3 QA = 56 Sum is 189 Match 1 Score = 87 Match 1, Team 1 "effective individual QA" = 95/189 * 87 = 43.7 Match 1, Team 2 "effective individual QA" = 38/189 * 87 = 17.5 Match 1, Team 3 "effective individual QA" = 56/189 * 87 = 25.8 In this case, teams with higher scores get rewarded with more credit for points in rounds when they played with normally underperforming robots. Also, the final sum of all teams represents the actual (normalized per regional) number of points scored at regionals, which more directly answers OP's question |
#15
That's really cool, thank you! The negative OPR threw me off for a while; it's strange how the top 90% has a higher total OPR than all teams.
Just some statistics I got from OPR data (I used column G on the "OPR results" tab from Ed Law's spreadsheet):
What's really interesting is that following the stats above compared to the ones I had about QA, OPR seems to peak off more quickly, but have a larger "middle" section. I feel like part of the issue is that the OPR data I had only took the higher value for teams that have competed twice, as compared to the QA which had everything. Graphing OPR vs QA gave me this: Which seems to have a steeper curve in OPR, but not by as much as the stats imply. If I have some time I'll redo the OPR calculations with full data and check what I did for the QA ones. |
