Go to Post There can be only one.... - Koko Ed [more]
Unread 22-03-2015, 15:44
paper: 2015 Week4 miscellaneous data and analysis
http://www.chiefdelphi.com/media/papers/3120
Unread 22-03-2015, 17:50
Re: paper: 2015 Week4 miscellaneous data and analysis
posted: Weeks 1thru4 OPRs from Qual Match Results data
Unread 22-03-2015, 20:08
posted: Weeks 1thru4 component OPRs (with surrogates removed)
and list of all surrogates in weeks 1thru4
Unread 22-03-2015, 22:26
posted: Week4 Playoff Match Results
Unread 23-03-2015, 12:53
posted: Weeks 1-4 DQ from Qual Match and Team Rankings data1
1FIRST was not reporting DQ data properly in the Qual Match data until Week4. Now that they fixed it, I had to re-download all 4 weeks and re-run the script. I think it should be correct now.
Unread 23-03-2015, 16:54
Has anyone else computed "component" (i.e. Coop, Auto, RC, Tote, and Litter) OPRs for combined weeks 1 through 4 data? I'd like to compare methods and results.
Unread 24-03-2015, 11:43
Planning for Week5:
Which (if any) of the attachments I posted are the most useful?
Are there other reports or data that you'd like to see?
Unread 25-03-2015, 15:30
posted: Weeks 1 thru 4 Playoff Match Results raw data
Unread 26-03-2015, 18:52
posted: Weeks 1 thru 4 single-event OPR from Qual Match Results data (each event solved and reported separately)
