Thread Tools |
Rating:
Display Modes |
Plastic Chain
Were are a 42 point stacking robot and can do 1 1/2 to 2 per match. We were picked by the #1 alliance in both of our districts. At this point we weight 119.5 pounds and use a elevator to raise the 6 totes , can and litter.
One of our mentors wants to add a can puller from the step. To do this we must lose weight and he wants to install plastic chain where we use metal chain now (lifting approx. 75 pounds). I feel that being a very high scoring robot it is not worth the risk of installing plastic chain. What are other teams experience using plastic chain ? |
Re: Plastic Chain
Have you done the math on the stress on your chain, to see if the proposed chain is adequate?
Re: Plastic Chain
No. Unless you have access to something special, plastic 35 chain usually isn't meant for more than 60 lbs of working load. It won't hold up under the rigors of competition.
Risk versus rewards. You are risking your primary scoring mechanism while trying to make something that is not going to contribute to your score in every match. |
Re: Plastic Chain
Re: Plastic Chain
Instead of plastic chain consider switch to timing belt. It should be a decent reduction in weight if you are currently running #35 chain.
Re: Plastic Chain
We are running 35# chain 4 of them approx. 12 feet long each so timing belt out of the question. Only 6 feet of each chain will be changed over to plastic. I see problems. What is that old line "Do not change horses in mid stream". PNW championships are in 5 days.
#7
Re: Plastic Chain
So you're running 4 12' lengths of #35 chain?
It requires new sprockets, but switching to #25 chain would provide HUGE weight savings and still be plenty strong. |
#8
Re: Plastic Chain
IIRC #25 chain is less than 1/4 the weight of #35 chain.
#9
Re: Plastic Chain
A little more than half, according to these guys. Still, at 0.23#/ft for 35 and 0.10#/ft for 25, that's 6# less of chain by switching to 25.
Also, you actually could switch to belts, you'd just have to use open length belting with a clamp to close it up. As long as you're running your lift a short enough distance that you don't have to run the clamp over a pulley, it'd be fine. Last edited by Kevin Sevcik : 27-03-2015 at 17:13. |
#10
Re: Plastic Chain
#25 chain is the way to go. It's great stuff. #35 chain is OVERKILL on all mechanisms except chain driven arm pivots in my opinion.
McMaster lists a working load of 88 lbs for #25 chain and 200! for #35. Acetal #35 chain is listed as 45 lbs working load. Last edited by RoboChair : 27-03-2015 at 18:27. Reason: adding additional info |
#11
Re: Plastic Chain
Consider also that you can allow yourself to use weaker material by decreasing the load applied. Adding a spring will add some weight, but it may allow you to save some weight elsewhere (chain weight, motors, and gearbox for example).
Also, if you are having trouble with belts as an alternative to chain, you can also try a simple string winch. You can find cord and wire in long lengths for cheap that are very strong for their weight. |
#12
Re: Plastic Chain
http://www.mcmaster.com/#constant-force-springs/=whvq22 |
#13
Re: Plastic Chain
But that adds up to like 23 feet of chain. Heavy. I know little about plastic chains, but if you're using #35 chain, you can switch to #25. Or even bicycle chain. Or lose the weight elsewhere. Switch to mini-cims. Canburgulars are very valuable and will make people want you. We designed one that weighed in at about 4 lbs. I think you can find four pounds. |
#14
Re: Plastic Chain
Re: Plastic Chain
I will ask for that to be calculated.
