Go to Post Collaboration works. DO IT. - Travis Hoffman [more]
Unread 28-03-2015, 15:13
Sav01027's Avatar
Sav01027 Sav01027 is offline
AKA: Sav Sidorov
FRC #5897 (Apex Robotics)
Rookie Year: 2015
Sav01027 is an unknown quantity at this point
Autonomous Inconsistencies
We're coding an Autonomous mode in preparation for our next regional, and we're running into a very odd issue. We have our code set up so that it calls methods into the autonomous code (i.e. drive() would make it drive forward a set number of encoder rotations).
The issue that we're having is that when we enable the robot to run Auto, it acts unpredictably. Say, one time it would do it perfectly, but the next it would turn for a different number of degrees, or drive for a different distance, while running on identical code.
We have tried resetting the code and the roboRio, as well as checking the encoder values in Teleop. At least in Teleop, the encoders seem to be working fine.
Has anyone encountered this problem before, or has a solution for it?
Thanks
Unread 28-03-2015, 18:07
Nyxyxylyth Nyxyxylyth is offline
AKA: Neal Manson
FRC #1481 (The Riveters)
Nyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really nice
Re: Autonomous Inconsistencies
Are you calling SetPosition(0) in your AutonomousInit() for the encoders, etc? Or whatever the appropriate equivalent initialization spot is in your setup.
Unread 28-03-2015, 18:51
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
What kind of Drivetrain do you have?
How are you driving? Are you using a PID loop or just driving until the encoders read a large enough value or what?
Unread 28-03-2015, 19:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I would try printing the encoder count to the smart dashboard on a heartbeat (perhaps 0.1 or 0.5 sec, depending on how fast you're going) and compare the results of the trials that work vs the ones that don't. There should be some sort of clue there.
Also, presuming that you are driving this on some variant of tank, you need to ensure that the counts of the two sides increase together. If one is getting ahead of the other, slow that side down a notch. Otherwise, you'll wind up curving off course, though the robot should straighten out to the correct orientation at the end if it hasn't hit anything.
Unread 29-03-2015, 13:56
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Check how you're treating the encoder during TeleopInit and TeleopPeriodic, are you reseting it in teleopinit and not autonomous init?
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 30-03-2015, 16:45
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Post your code?
