Go to Post I am a geek and proud of it. - +()c|D [more]
Unread 05-04-2015, 07:49
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Smile Getting the Totes Right Side Up from the Chute Door
I've seen that some teams could get the totes right side up out of the tote chute. Normally totes tend to fall over when they fall on the carpet and there is obviously a technique to prevent that.
Can someone explain what are the methods in order to achieve that?
Thank you!
Edit:
I guess I didn't explain my intention well enough,
What I intended was getting the tote right side up without touching the robot (only the carpet)
You can see it very well in this video: https://www.youtube.com/watch?t=45&v=oiOZN4G4OxI
Look at the bottom right feeder (red side). Team 548 get the tote right side up every time.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 05-04-2015, 08:13
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Getting the Totes Right Side Up from the Chute Door
We have a lip extending out from our frame to "catch" the front edge of the tote before the tote hits the floor. We back up slightly and the tote falls upright.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
Hi, there are a few techniques that I've seen.
Some teams are building ramps, which they tether to their robot, so the totes slide nicely into the field.
Some teams push a tote - often one of the yellow totes - up to the chute door. (yes, chute door) The long side of the tote is against the wall. This creates a ramp of sorts, and totes generally bounce over the "ramp tote" and land upright on the field. It does not seem 100%, but it works pretty well.
I've not seen this myself, and my team didn't play with it since we have a slide built into our robot, but I've read that some teams will, as the tote is sliding down the chute, lower the door onto the top of the tote before it exits the chute - and are able to bump it in such a way as to help it land upright.
Hope that helps!
Steve
Unread 05-04-2015, 09:11
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
We have an actuating claw for our lift, so we line up at the feeder station, and close the claw on the tote before it hits the ground, open, and it lands flat. It has worked every time, providing we are lined up with the chute door.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 05-04-2015, 10:08
SeanFitz's Avatar
SeanFitz SeanFitz is offline
1st Year Mentor
FRC #2877 (LigerBots)
SeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of light
What we do is set our robot a little ways away from the door, and then just let the tote fall naturally. The front hits our robot and the rest falls back onto the ground level and ready to be picked up. It might be a little slower than using a ramp, but it saves weight and has yet to fail us once.
"A good driver always beats a good robot"
2015: 2 Chairman's Awards, 1 Finalist Medal, 1 St. Louis Alliance Captain Hat (7th Seed Newton)
2014: 1 Blue Banner, 1 Finalist Medal, 1 Amazing time in St. Louis.
Unread 05-04-2015, 10:33
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Our team discovered this by accident. If our grabber is closed, the tote will land on the grabber. Then the driver opens the grabber, and the tote lands on the floor right side up. Then the driver can grab the tote correctly.
Unread 05-04-2015, 11:08
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Our team has a method that I haven't seen many others use in the form of a conveyor belt through the middle of our robot. We load totes into the back of the robot and they slide out to the front where our stacking mechanism is located. We also have two rails that actuate in and out (one on each side of the tote) to re-align the tote if we didn't back up to the chute perfectly square.
It's not done until it's overdone!
Unread 05-04-2015, 12:10
GuyM142's Avatar
AKA: Guy
Thanks for all the comments!
But I guess I didn't explain my intention well enough,
Unread 05-04-2015, 12:21
Neima's Avatar
Neima Neima is offline
College Student
AKA: Neima Yeganeh
FRC #3082 (Chicken Bot Pie)
Neima is an unknown quantity at this point
I don't know how they are doing that in that video but at 10k lake I saw a team able to do that too. Their human player would barely put the tote in the chute then let go of it and open the chute door before the tote would hit the door. This allowed the tote to gain enough speed to not tip on its side. I asked the head ref about it and he said it was a grey area.
2012 10,000 Lakes Regional - Semifinalist
2013 10,000 Lakes Regional - participant
2014 10,000 Lakes Regional - Semifinalist
2015 10,000 Lakes Regional - participant
2016 Finding Myself - participant
Unread 05-04-2015, 12:30
msaunders msaunders is offline
AKA: Mike Saunders
msaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nice
I was intrigued also.
I am uploading some close up videos from Bedford.
2015 Bedford FRC548 HP Tote Loading
548 does not use a ramp. I think I saw one tote that did not land flat.
2015 Bedford FRC 2137 HP Tote Loading
-= 862 =- Lightning Robotics, Canton, MI
2015 FiM Bedford District Chairman's Award
2014 FiM Bedford District Winner
2013 12th seed, Curie Division Winner with 1678 and 148
2013 Michigan State Championship Entrepreneurship Award
2013 FiM West Michigan District Winner, Engineering Inspiration Award
2013 FiM Kettering District Winner, Engineering Inspiration Award
Unread 05-04-2015, 12:51
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
I've seen a few human players smack the tote with the chute door by slamming it down on the back end of the tote as it goes through, and it kind of lifts the front end of the tote enough for it to land right.
Edit: yeah, same method as previous post ^
Unread 05-04-2015, 12:34
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Hi, as far as getting the tote to land perfectly without it touching anything but the chute, I'd say it comes pretty much down to luck. Our human tried a lot of different things like angling the tote in the chute and hitting the tote with the door on the way out to slow it down. None of these techniques yielded a desirable outcome. :/
However, we are able to get the totes out of the chute perfectly every time without touching them with our robot. Well, technically it does touch our robot. We built a table that sits in front of the chute that catches the totes and lets them land perfectly every time. This table is tethered to our robot so we can move independently from it #teamtether. We call it "El Stackador"
https://drive.google.com/file/d/0B8z...ew?usp=sharing
Now, obviously this won't work for you if you are usually picking up from the ground. What you might want to try is building just the top of the table and sitting it on the ground where the totes land, possibly with an open front if your robot sucks the totes in from the front. I know team 3310 has a similar mechanism that acts like the top of our table, but it fold down from the front of their robot.
Good luck,
-3481
Unread 05-04-2015, 12:42
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
I've seen teams slam the chute door down on the back end of the tote as it's exiting the chute. It seemed to be effective in getting the tote to land in a nice orientation.
Unread 05-04-2015, 12:48
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
It's not luck; it's practice. There are actually [at least] two main methods, one faster than HPs typically go and one slower. Neither involves violating G5, G6 or any other rules. There's no visible delay in overall throughput between them, though in reality there probably is some incremental difference. Personally I find the slower approach easier and more consistent--actually, I had trouble making totes land on end that way--but I know people who can do the faster approach all day long.
Actually, on looking at the 548 video, I'm not sure he's doing either approach I mentioned. (Though he may be; it's hard to tell.) So maybe there's more than two approaches.
Unread 05-04-2015, 13:57
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Our human player ( Cameron) has done 100% at some Districts of the totes landing flat. Other teams have filmed him with slow motion cameras to see how he does it. I told the other teams to ask Cameron for some lessons no secrets in FIRST. Now we will tell you Cameron taps the last 10-15% of the tote as it is leaving the chute with the door. If you want lessons you must come to the Northwest. You can go to http://pnwfirst.org/
we are at District 4 , District 7 and Championship. Cameron is on team 4061. Good luck.
