Go to Post Don't trust everything you read on Chief Delphi. - Peter Matteson [more]
Unread 08-04-2015, 17:02
DrWateryCat DrWateryCat is offline
AKA: Kenny Raisbeck
FRC #2186 (Dogs of Steel)
DrWateryCat is an unknown quantity at this point
RoboRIO as I2C slave?
Hi all,
I would like to use a Raspberry Pi running a web server with a custom webiopi page as a kind of remote console to tweak certain aspects, such as other auto modes. Is there any way in WPIlibJ to accomplish this?
Unread 08-04-2015, 17:33
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: RoboRIO as I2C slave?
Is this intended to be used in competition?
Unread 08-04-2015, 17:49
AKA: Kenny Raisbeck
Not really, just more as a cool thing I can show my team and use in an offseason competition in septemberish.
Unread 08-04-2015, 18:29
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
It's probably easier to just wire your Pi into the router and use NetworkTables for communications. If you use pynetworktables2js, then you can talk directly to NetworkTables from javascript... and of course, if you're doing that, you don't even really need to run the web server on a Pi unless you want to.
Unread 08-04-2015, 23:33
jgalbraith jgalbraith is offline
AKA: James Galbraith
FRC #0231 (High Voltage)
jgalbraith is an unknown quantity at this point
You can use the parameter system in the SmartDashboard to write modified constants to the RoboRIO. This system needs to be used carefully as it can damage the flash memory.
Better in my opinion is to create a parameter file in /home/lvuser or a subdirectory thereof and read in the parameters on robot initialization. You could modify the file via ftp. Restart the robot code via the driver station to check out the changes.
Edit: another option is to modify the file on the RaspberryPi and then use it to FTP the file to the roboRIO.
Unread 29-04-2015, 16:16
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
The easiest way IMHO is to use:
  • SmartDashboard.getNumber() - Use to return doubles. You should use SmartDashboard.putNumber() first to give yourself a place to input the number.
  • SmartDashboard.getString() - Use to return text. Again use putString() first
  • SmartDashboard.getBoolean() - Use to return true or false. Use putBoolean() first.
There are different ways to display these things on SmartDashboard as well such as choosing View>Editable in the menubar then right clicking on different objects to change their appearance, etc.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
