Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
Unread 15-04-2015, 08:32
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
This is RAD
RAD is a pretty cool utility the CSA from NI showed me at one of the regionals this year. It allows you to backup and deploy an image of your RoboRio.
Check it out...
http://www.ni.com/example/30986/en/
Replication and Deployment (RAD) Utility
Imaging is an effective tool for managing the software deployments of real-time (RT) targets. However, building a robust application to automate application deployment and management of real-time targets with imaging APIs is not a trivial undertaking. The Replication and Deployment (RAD) reference utility provides a turn-key solution for automated RT image deployment, replication, and management. It is built using functionality provided by the System Configuration VIs.
The views expressed are mine and should not be construed to represent the views of anyone else.
