Go to Post Its always good to read the rules yourself rather than listen to "word of mouth" rules. - Killraine [more]
Unread 21-04-2015, 11:47
GCarnes's Avatar
GCarnes GCarnes is offline
FRC #5150 (Hybrid Hornets)
Team Role: Driver
GCarnes is just really niceGCarnes is just really niceGCarnes is just really niceGCarnes is just really nice
Practice Chassis
Does anyone have any recommendation or designs to help my team create a practice chassis? We are looking for something to be used for drive practice and mechanism testing. So, something that can accept different transmissions and drive trains. It would also need many different mounting spots for any mechanisms that we would like to test. Looking for something cheap. It could be a kit from Vex or Andymark or something we would have to create ourselves.
Unread 21-04-2015, 11:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Practice Chassis
Maybe you could practice designing and building chassis, as well as drive trains and mechanisms. There are a whole bunch of ways to make a chassis, and which materials and methods you should use might depend on what type of equipment and expertise your team has (or wants to acquire).
As an example, over the years we've built our robots with chassis made of welded steel, glued and stapled plywood, riveted or bolted fiberglass, and bolted or riveted aluminum. We don't have the equipment and expertise to use welded aluminum, which is what many teams use.
Unread 21-04-2015, 11:55
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Send me a PM, hopefully you are close enough in the mitten to stop by and check out some options before you buy anything. I would lean heavy towards versa chassis with some versa blocks to start (WestCoast Drive) and then later you can purchase some clamping gearboxes from vex and start your experiments with another bread of drive trains. The 1x2 versa tubing on the drive makes it super easy to add other components.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 21-04-2015, 16:23
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Before my first season my team built a practice drive using the 2013 Vex drive in a day kit. Both this and the 2014 drive in a day kits are available. I can also see the benefits of having students gain experience building a drive from scratch, which should be less expensive.
Unread 21-04-2015, 16:30
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Originally Posted by RonnieS View Post
Send me a PM, hopefully you are close enough in the mitten to stop by and check out some options before you by anything. I would lean heavy towards versa chassis with some versa blocks to start (WestCoast Drive) and then later you can purchase some clamping gearboxes from vex and start your experiments with another bread of drive trains. The 1x2 versa tubing on the drive makes it super easy to add other components.
-Ronnie
I second this. Basically everything you buy will be reusable, except possibly the frame itself. We have ran some derivation of a versachassis for the past two years due to how customizable it is and how quickly it comes together.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
