Thread Tools |
Rating:
Display Modes |
pic: In-Line Pneumatic Fittings
Re: pic: In-Line Pneumatic Fittings
We used this SAME setup on our robot "Team THRUST 1501". The net savings in weight is about 0.3 lbs per using the Norgren Regulator. We tested it in our practice robot for 8 weeks with no issues.
Anybody know where we can find the pressure ratings? I'm sure they are legal, but inspectors like the see that kind of stuff, and I can't find it on their website. But these do look really awesome. Especially with those U fittings they sell, we could make a much lighter and smaller setup.
http://www.automationdirect.com/stat...linegauges.pdf |
I have used these too, they are fantastic. Very happy they are a bit orange to o.
Looks like a fantastic part, and the sort of thing I hope we see more of (if it's legal). My advice would be to file it away for future reference, and wait to see if it's determined to be legal in the future. I hope it is, I want to use it on my robot. Insert standard disclaimer here about all previous year's rules not applying in all future years ![]() |
#8
I assume that this is a relieving regulator, is that correct? If it isn't, I'm going to have to concur on the "maybe shouldn't have passed inspection" crowd. If it is, I think I'll pass the info on to my team...
#11
Does this even pass rule 66 G?
Is it worth using these type of fittings when the brass fittings do a good job in serving as a heatsink for the compressors?
#13
So yes, if both components are legal then it's worth it to us (and many others) |
#14
It depends entirely on how much air you need. If you're using air solely to shift gears, probably not. If every function other than drive is pneumatic, quite possibly. We blew out several hoses (with a crack like a .22) during practice for rebound rumble. We had a pneumatic climber, but we didn't even have the climber attached yet. We were just making adjustments to the Frisbee primer that required depressurizing the system. In filling up our (seven?) plastic tanks, we blew out the hose at the end nearest the compressor. The large quantity of air depressurizing through the rupture cooled the tubing back down, so it took us several swaps to figure out that it wasn't just defective tubing. This was followed by closer monitoring to figure out the actual cause. Our solution was to relocate as much of the brass as possible to before the first piece of tubing, and continued monitoring for swollen tubing.
#15
Just as a note: If I'm not mistaken, these would be located well downstream from the compressor, say on the other side of the storage tanks. This isn't the pressure relief valve, it's a regulator. The PRV has a specific part number, and must be hard-mounted.
