Go to Post If only all this food for thought happening in this thread could somehow be funneled into solving world hunger... - artdutra04 [more]
Unread 27-04-2015, 21:38
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Ether's swerve code for 2015 Control System
Hey there CD,
As an offseason project I took Ether's paper on calculating swerve angles and speeds and turned it into an all-in-one java class for driving using a single 3-axis joystick. This was something I threw together in a few hours today and haven't really tested at all (it's my schools vacation week so it'll be a while before I can test it and we don't even have a swerve base to use) but it's something you can use as a starting point for your swerve. I am 100% sure that there is something more that teams/users would need to do before this code is ready for competition, again only a starting point.
Github repository
package org.usfirst.frc.team3467.robot;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.SampleRobot;
 * This is a short sample program demonstrating how to use the Talon SRX over
 * CAN to run a closed-loop PID controller with an analog potentiometer.
public class Robot extends SampleRobot {
  CANTalon FLdrive, FLsteer, RLdrive, RLsteer, FRdrive, FRsteer, RRdrive, RRsteer;
  Joystick driveJoy;
  Gyro gyro;
  public Robot() {
      FLdrive = new CANTalon(1); // Initialize the CanTalonSRX on device 1.
      FLsteer = new CANTalon(2);
      RLdrive = new CANTalon(3);
      RLsteer = new CANTalon(4);
      FRdrive = new CANTalon(5);
      FRsteer = new CANTalon(6);
      RRdrive = new CANTalon(7);
      RRsteer = new CANTalon(8);
      driveJoy = new Joystick(1);
      FLdrive.changeControlMode(CANTalon.ControlMode.Voltage);
      RLdrive.changeControlMode(CANTalon.ControlMode.Voltage);
      FRdrive.changeControlMode(CANTalon.ControlMode.Voltage);
      RRdrive.changeControlMode(CANTalon.ControlMode.Voltage);
      FLsteer.changeControlMode(CANTalon.ControlMode.Position);
      RLsteer.changeControlMode(CANTalon.ControlMode.Position);
      FRsteer.changeControlMode(CANTalon.ControlMode.Position);
      RRsteer.changeControlMode(CANTalon.ControlMode.Position);
      FLsteer.setFeedbackDevice(CANTalon.FeedbackDevice.AnalogPot);
      RLsteer.setFeedbackDevice(CANTalon.FeedbackDevice.AnalogPot);
      FRsteer.setFeedbackDevice(CANTalon.FeedbackDevice.AnalogPot);
      RRsteer.setFeedbackDevice(CANTalon.FeedbackDevice.AnalogPot);
      FLdrive.setFeedbackDevice(CANTalon.FeedbackDevice.QuadEncoder);
      RLdrive.setFeedbackDevice(CANTalon.FeedbackDevice.QuadEncoder);
      FRdrive.setFeedbackDevice(CANTalon.FeedbackDevice.QuadEncoder);
      RRdrive.setFeedbackDevice(CANTalon.FeedbackDevice.QuadEncoder);
      FLsteer.setPID(1, 0, 0);
      RLsteer.setPID(1, 0, 0);
      FRsteer.setPID(1, 0, 0);
      RRsteer.setPID(1, 0, 0);
  public void operatorControl() {
    while (isOperatorControl() && isEnabled()) {
    	double fwd;
    	double str;
    	double rcw;
    	double temp;
    	double fwd2;
    	double str2;
    	double wheelbase;
    	double trackwidth;
    	double r;
    	double a;
    	double b;
    	double c;
    	double d;
    	double frs, fls, rls, rrs; //Front Right, Front Left, Rear Left, Rear Right Wheel Speeds, respectively
    	double fra, fla, rla, rra; //Wheel Angles
    	double max;
    	fwd = driveJoy.getY();
    	str = driveJoy.getX();
    	rcw = driveJoy.getZ();
    	temp = (fwd*Math.cos(gyro.getAngle())) + str*Math.sin(gyro.getAngle());
    	str2 = (-fwd*Math.sin(gyro.getAngle())) + str*Math.cos(gyro.getAngle());
    	fwd2 = temp;
    	wheelbase = 30; //length of drivebase
    	trackwidth = 24; //width of drivebase
    	r = Math.sqrt((wheelbase*wheelbase) + (trackwidth*trackwidth));
    	a = str2 - rcw * (wheelbase/r);
    	b = str2 + rcw * (wheelbase/r);
    	c = fwd2 - rcw * (trackwidth/r);
    	d = fwd2 + rcw * (trackwidth/r);
    	frs = Math.sqrt(b*b + c*c);
    	fls = Math.sqrt(b*b + d*d);
    	rls = Math.sqrt(a*a + d*d);
    	rrs = Math.sqrt(a*a + c*c);
    	fra = Math.atan2(b,c) * 180/Math.PI;
    	fla = Math.atan2(b,d) * 180/Math.PI;
    	rra = Math.atan2(a,d) * 180/Math.PI;
    	rla = Math.atan2(a,c) * 180/Math.PI;
    	//Because the CANTalon position control uses values from 0 - 1023
    	//for potentiometer ranges, we must modify the wheel angles to
    	//compenstate for this. To do this add 180 to the wheel angle to
    	//get a 0-360 range then multiply by 1023/360 which equals 2.8444...
    	FRsteer.set((fra+180) * (1023/360));
    	FLsteer.set((fla+180) * (1023/360));
    	RLsteer.set((rla+180) * (1023/360));
    	RRsteer.set((rra+180) * (1023/360));
    	//Normalize wheel speeds as stated in Ether's document
    	max = frs;
    	if(fls>max){
    		max = fls;
    	if(rls>max){
    		max = rls;
    	if(rrs>max){
    		max = rrs;
    	if(max>1){
    		frs/=max;
    		fls/=max;
    		rrs/=max;
    		rls/=max;
    	//Wheel speeds are now 0-1. Not -1 to +1.
    	//Multiply wheel speeds by 12 for voltage control mode
    	FRdrive.set(frs*12);
    	FLdrive.set(fls*12);
    	RRdrive.set(rrs*12);
    	RLdrive.set(rls*12);
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 28-04-2015, 23:15
EmileH's Avatar
AKA: Emile Hamwey
Re: Ether's swerve code for 2015 Control System
Also created a Simulator today to test this. Just paste into eclipse/nb and go.
import javax.swing.JOptionPane;
public class Simulator {
 * This program is based off of Ether's swerve drive kinematics and
 * algorithms.  I take no credit for the calculations used in this code.
 * @param args
	public static void main(String[] args) {
	   	double fwd;
    	double str;
    	double rcw;
    	double getAngle;
    	double temp;
    	double fwd2;
    	double str2;
    	double wheelbase;
    	double trackwidth;
    	double r;
    	double a;
    	double b;
    	double c;
    	double d;
    	double max;
    	String getfwd = JOptionPane.showInputDialog("Please Input negated Y joystick value");
    	String getstr = JOptionPane.showInputDialog("Please Input X joystick value (-1 to 1)");
    	String getrcw = JOptionPane.showInputDialog("Please Input Rotational Joy Value (-1 to 1)");
    	String getgyro = JOptionPane.showInputDialog("Please Input Gyro Angle (0-360)");
    	fwd = Double.parseDouble(getfwd);
    	str = Double.parseDouble(getstr);
    	rcw = Double.parseDouble(getrcw);
    	getAngle = Double.parseDouble(getgyro);
    	temp = (fwd*Math.cos(getAngle)) + str*Math.sin(getAngle);
    	str2 = (-fwd*Math.sin(getAngle)) + str*Math.cos(getAngle);
    	fwd2 = temp;
    	// we must modify the wheel angles to
    	//get a 0-360 range
    	System.out.println("Front Right Wheel Angle" + ((fra)));
    	System.out.println("Front Left Wheel Angle"  + ((fla)));
    	System.out.println("Rear Right Wheel Angle"  + ((rla)));
    	System.out.println("Rear Left Wheel Angle"   + ((rra)));
    	max = frs;
    	if(fls>max){
    		max = fls;
    	if(rls>max){
    		max = rls;
    	if(rrs>max){
    		max = rrs;
    	if(max>1){
    		frs/=max;
    		fls/=max;
    		rrs/=max;
    		rls/=max;
    	System.out.println("Front Right Wheel Speed"+ (frs*12));
    	System.out.println("Front Left Wheel Speed" + (fls*12));
    	System.out.println("Rear Right Wheel Speed" + (rrs*12));
    	System.out.println("Rear Left Wheel Speed"  + (rls*12));
