USB Serial Port
Our team will be switching to Java from Labview over the summer so I went digging into WPILIBJ and saw that you could initialize the serial port as the RS-232, MXP UART, or the USB. To my knowledge you couldn't use USB in Labview.
http://first.wpi.edu/FRC/roborio/rel...1 _1Port.html Has anyone used this? Can you chose which USB port? |
Re: USB Serial Port
In order to do this you have to use a Usb to serial adapter. And it will recognize the serial port.
Re: USB Serial Port
A little late, but here's a version of the LabVIEW serial port open that supports the first USB serial device.
Java and C++ kUSB only support the first USB serial device. |
