pic: LEGO Coaxial Swerve Module
Re: pic: LEGO Coaxial Swerve Module
I recommend tetrix (?) chain. Using gears to do it would be awkward looking IMO. |
I have worked a lot with LEGO technic construction, even tried my hand at this a couple of times. 24t gears between turntables was promising. You will be putting way to much stress on chains. The key for all of this is to support the gears as best as possible. Your module is nice and compact. The only recommendation I would have is replace the 3-long axel on that 12t with something to run the full length between the two 3x5 liftarms. This will keep the 12t from skipping with the 20t, attached to the wheel, as well as prevent the driving gear from falling off its axel.
How much does it weigh?
I think you got carried away with the pocketing.
Ok, this is pretty cool. Thank you for posting it.
What supports the drive shaft? Is there something to limit upward travel of the drive gear? The rest of your design is easier to see in this render. |
#7
Thanks for all of your helpful replies!
I have a question of my own regarding the TETRIX chain as I have never worked with it. Is it compatible using the LEGO gears as sprockets? I have a good amount of LEGO chain, but it tends to fail quite easily. If I can't use chain, I have a design that connects all of the modules together with 40 tooth gears. It seems to work well, but I haven't tested it with all four modules because I only have one module until my order of parts arrives. In the image, some parts are a bit hard to see from this angle, so I can clarify them. The reason the 12 tooth gear is on a 3m axle is because if I extend it across between the liftarms, it rubs on the tire. The way it is now is the best solution I could come up with. And yes, the vertical drive shaft is supported by the black piece that you can barely see right below the turntable. The drive gear cannot move upward because of it. As for weight, the module weighs about an eighth of a pound, probably one of the lightests swerve designs ever. I might be able to get a another render at a different angle so that the underside of the turntable can be seen better. |
#8
Did you try it physically? I didn't have issues with a long axel.
#9
This is cool and so elegantly compact. The one Steve made is cool too.
Did you want to use the chain or 40-tooth gears for turning the modules, for powering the drive wheels or for both? Have you considered using long axles and the knob-gears Calvin referred to? The axles aren't that great at resisting torque but then you get gear lash with a large number of gears. For "Smart Move", one of the local whizz kids and his partner attempted to build a second robot with swerve/crab drive for the Championship in February, after the Qualfier in November. I think their school ran out of parts and they could not manage to get the software going (no mentors on his FLL team). They did end up winning Third Place in Robot Performance using a robot they started building less than 24 hours before the Championship. |
#10
Asking the real questions here.
This is a really cool adaption to a complex concept, well done! |
#11
We're looking at working on some swerve this summer and we might have to build this to play around with control concepts. Awesome job.
#12
This is definitely cool, but I think in order to survive the obstacles from (e.g.) my childhood bedroom you'll probably want 3 pods rather than 4, and maybe some bigger wheels
![]() LEGOs + one of those electric race car tracks (even the simple figure 8) FTW. |
#13
To the OP: Search for "synchro drive" in the website I linked and you'll find tons of examples by people who have done very similar things for years now. ![]() And because you are going crab, as an extra challenge, make it drive and steer with one motor total (doesn't have to be at the same time). Yes, it is possible. |
#14
Definitely want the axle for the idler gear to go across, otherwise it will shake loose / skip teeth / add friction. If you have clearance issues, a different wheel could be used. Lego parts 3482 (wheel) and 3483 (tire) clear the axle with that gear spacing.
More wheels: http://isodomos.com/Visual-Parts-Helper/Lego-Wheel.html Here's a tiny LEGO swerve drive I made ages ago, using the differential gear piece as the swerve body and bearing. It drove around fine, but in the end they're still tiny plastic parts and can't handle a lot of load. http://www.chiefdelphi.com/media/photos/28935 http://www.chiefdelphi.com/media/photos/28936 |
#15
I haven't tried one of these in years, perhaps it would be worth another go.
Perhaps try using the 4-knob gears? They keep a strong connection if you brace them well enough, though you won't get the same ratio, of course. Last edited by Calvin Hartley : 05-06-2015 at 14:26. Reason: I missed a comma. |
