Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 11-06-2015, 21:22
maglax's Avatar
maglax maglax is offline
AKA: Michael Glass
FRC #3966 (L&N STEMpunks)
maglax is an unknown quantity at this point
The Dreaded FRCSim
Has anybody had success in installing FRCSim on Ubuntu 15.04? My laptop keeps failing at downloading some files off their server
W: Failed to fetch http://first.wpi.edu/FRC/roborio/release/linux/dists/vivid/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://first.wpi.edu/FRC/roborio/release/linux/dists/vivid/main/binary-i386/Packages  404  Not Found
Should I just run 14.04 in a VM or is there a work around?
Any help Appreciated.
Unread 11-06-2015, 21:25
Jared's Avatar
Jared Jared is offline
Re: The Dreaded FRCSim
The instructions here (http://wpilib.screenstepslive.com/s/...talling-ubuntu) specify Ubuntu 14.04. Others have had problems when using the wrong version of Ubuntu.
Unread 11-06-2015, 21:49
maglax's Avatar
AKA: Michael Glass
Should I run 14.04 in a vm then?
Unread 11-06-2015, 23:38
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
One of the other mentors on our team was unable to get it to work in a VM. It seemed to be some issue with the video drivers. You may get lucky but I'm afraid you may want to temper your expectations.
Unread 12-06-2015, 07:13
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
What you may want to try instead of a VM is installing Ubuntu 14.04 onto a flash drive, and then use the GRUB bootloader you installed for 15.04 to boot from that. It allows you to use your native hardware/video drivers but not mess up your existing installation. I recommend using a flash drive that's 16 gb or larger, but 8gb should work too.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 12-06-2015, 09:17
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
If you want to try to get it to work on 15.04, you can get it to download (and get rid of the 404) if you change the repository version from "vivid" to "trusty", in the Ubuntu software sources settings.
Unread 12-06-2015, 09:21
ty.sayman ty.sayman is offline
FRC #5190 (Green Hope Falcons)
ty.sayman is an unknown quantity at this point
It is possible.
I got FRCSim working on 14.04 in a Parallels 10 VM a few weeks ago.
This post had some helpful hints:
http://www.chiefdelphi.com/forums/sh...d.php?t=133104
Unread 13-06-2015, 00:51
AKA: Eric
I should add that I believe this was using VirtualBox.
