Go to Post FIRST cannot enforce Gracious Professionalism on the participants in this program, you will have to do it on your own. - Ken Leung [more]
Unread 29-06-2015, 22:02
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
Summer Swerve Project
This is the current project that I am working on.
The "cream" colored parts above the module are 3d printed, similar to those on 1991's 2015 swerve modules, except much smaller.
Unread 29-06-2015, 22:16
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Summer Swerve Project
Looks very light and strong. A few questions:
-Any reason why you chose to go with a live axle instead of a dead axle (or are you just using a 7/8" bolt)?
-How are you constraining the pulley on the CIM shaft radially?
-Are you broaching the bottom miter gear for a 1/2" hex shaft?
-What are your free speeds and weight?
Unread 29-06-2015, 22:27
TAlholm's Avatar
Mainely CAD
AKA: Tim Alholm
I will be changing it to a 3/8" dead axle, keeping it as it is for now to allow an easier time when putting in different setups (i.e. sprockets, pulleys, gears)
The bottom miter gear will be a keyed 1/2" bore, and the rest of the shaft will be 1/2" hex.
Free speed is currently 15.89 ft/s with a 5.83:1 reduction. Will be reduced more if I change the top HTD pulleys to GT2. The weight will be posted once I add the rest of the parts.
Unread 29-06-2015, 23:11
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Where is that miter gear coming from? I haven't found a good source for keyed miters yet. Unless you already own a key broach and not a hex (which I would recommend buying; they're quite useful, if expensive).
16fps is a good number.
Unread 29-06-2015, 23:51
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
This is a 1/2 keyed miter gear that has the same DP and teeth count as the vexpro miter gears. It's expensive though, at $82 a set.
Does the OP have a cheaper source?
FWIW, I do agree that a hex broach comes in handy.
Unread 30-06-2015, 13:08
TAlholm's Avatar
Mainely CAD
AKA: Tim Alholm
This is the miter gear I have chosen.
I will be looking into using a 1/2" Hex broach for it, thank you for the recommendation.
Also, the weight is roughly 6.75 pounds.
