Go to Post Not even close to ready...can we delay it till like...January 2010? - Cory [more]
Unread 07-07-2015, 18:43
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Design Documentation Best Practices
I am curious what sort of design documentation practices teams have? I have observed a few threads about CAD sharing, and code sharing, and about solving problems.... I am curious if any teams feel they ahve a really great documentation process that they would like to share on CD.
IE documentation of scoring analysis, strategy derivation, functional decomposition, Prototype results, architecture development/solution, design calculations (motor & gearbox selection), detailed design, design changes (and change processes), component and subassembly tests, integration, system testing, system tuning, practice, design changes due to seeing competitors, design changes due to stuff breaking, strategic shifts mid comp season.....
The closest I have observed were some teams that kept build blogs, which is definitely a type of design documentation. What others are out there that teams use? Any success or best practices worth sharing?
Unread 07-07-2015, 18:58
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Design Documentation Best Practices
My team keeps Google Drive engineering journals, which work pretty well. The challenge with those is getting enough people to contribute to keep them up to date.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-07-2015, 20:02
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
I think that's a challenge everywhere.
So how did your team overcome this challenge?
Unread 07-07-2015, 20:37
Custom User Title
AKA: Cal
With limited success.
As you can see, relatively few people contributed entries to them.
Unread 14-07-2015, 00:20
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
Team 1002 did a build notebook that had a large portion of our build time documented. It was our first season doing so, so it had varying degrees of completion from day-to-day. Overall, it was a good experience for the students.
You can check it out here:
https://docs.google.com/document/d/1...it?usp=sharing
Team 1002 - Website - Facebook - Twitter - Youtube
Unread 14-07-2015, 07:58
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Thank you all for sharing so far. One of the benefits of South East Michigan is that you can visit with teams and have lunch with friends that run/have run teams.
I had lunch the other day with two mentors that were the only technical mentors for a team for several years. While this was not the most competitive team, it often did very well, especially considering that there was a very high turn-over with their school, so they had a bit of "perpetual rookie syndrome" from the student perspective.
These mentors said a lot of their success was due to "standard work". IE, there are a set of chassis calculations they run for geartrain analysis that leads the design effort. There is a period of rule reading, and then strategic objective ranking, and several other exercises.
The benefit of the standard work was not allowing simple things to fall through the cracks or for the knowledge to fall to the side as "we always use 8 inch wheels..." and other best practices that turn into assumptions.
This "standard work" reminded me a lot of the influence and practices I read about in "The checklist manifesto". I originally read this book as I thought it would help me make better checklists for pit/match preparation. While reading it, I realized it has a lot of potential for utilizing a Design Checklist.
The team I worked with this year did not use such a list, and after starting build, we realized a very awkward problem. We were 1/2" short in several directions from having a good battery placement. We ultimately found a compromise, but had we used a checklist to verify placement of key components before starting build, we would ahve realized the issue, and just designed in the chassis the extra 1/2". This would have dropped the batter position about 4 inches lower, which would have been beneficial from a Center of Gravity perspective.
What items might a Chassis Standard Work Checklist include?
