What software program/language is best for roboRio?
I've been out of the game for some time but interested in helping my community start a team. One of the first aspects I was looking to brush myself up on was the "brain," for the robot. I noticed here on this link https://wpilib.screenstepslive.com/s...onent-overview that LabView was suggested. It has been awhile since I have used this program and I was about to delve into tutorials and videos for it but wanted to know what the community would suggest is the "best," program or language to utilize.
Thanks |
Re: What software program/language is best for roboRio?
If you don't have a lot of programming experience, either with the students or the mentors, I would recommend it as well. Teaching LV is fairly easy, and its easy to get a robot up and going. A lot of the more advanced teams use either C++ or Java because it does allow for easier multi user development, code reviews, and they run faster then LabVIEW (Although with the RoboRIO this is much less of a problem then it used to be). However, if you are just starting, I would recommend LabVIEW just because of the support you will be able to get. |
My team has always used LabVIEW and is very happy with it. I also know how to program in Java (not robot programming, but still) but I actually prefer using LabVIEW.
If you learned to program with a traditional text-based language, the transition to block-based may be difficult and you may consider Java or C++ (or one of the other options). If you don't have much programming experience, LabVIEW is great for both beginners and experts, and it isn't very hard to learn. Some people complain that there isn't much support for it at regional events, as many teams are switching over to Java or C++, but this has never been a problem for me in my 3rd year as head programmer. All things considered, once you are proficient in any language the limiting factor is the programmer, not the langage. |
I personally prefer Java over LabVIEW. I have been on 2 teams that recently switched between the two (one team from Java to LabVIEW, one team from LabVIEW to Java), and the students on both overwhelmingly prefered Java.
In general, there are more teams that use LabVIEW. But from what I have seen, New England has a ton of Java teams, especially among the top teams that you would usually go to for assistance. There is also support at a lot of local events from the crew at WPI that codes the FRC Java/C++ libraries. The biggest downside is that the initial hurdle of teaching students the basics of Java is a lot tougher than teaching LabVIEW. But once they know the syntax, it is fairly easy to write FRC code (if you are concerned about difficulty, just use RobotBuilder). I would heavily caution against using LabVIEW if your team has a lot of students with prior coding experience. I don't think I have ever seen someone enjoy going from a text-based object-oriented language to LabVIEW. Also, C++ is very similar to Java, especially in the context of FRC. Most of what I said above applies to it aswell. |
Do you have any students or mentors who already know some programming language or would be willing to start learning one before the season starts? If not then you probably want LabVIEW.
Do you have any students or mentors who already know or would be willing to start learning before the season starts C or C++ or assembly or some other language with manual memory management? If so then C++ is an option for you. If you answered yes to the first question and no to the second question you probably want Java. |
I would recommend sticking to a "traditional" text-based language (i.e. C++ or Java) simply because I believe the skills learned are much more easily transferable to other contexts.
Having used the WPI "command based" Java framework for the first time last year, I can safely say that it is reasonably well-documented and very intuitive. |
#7
We have been using Labview since we started. We like the support and have not found it to be at all limiting in what we can do - I think the most common advice is to go with a language that your programming mentor knows best. We know of CT teams that perform well in LV, Java or C++.
Since I see you are in CT - can I ask what commnuity? The Connecticut teams have become increasingly close and have a common interest in helping all of the teams improve their performance level. There are many here that will like to help a new team - feel free to PM if we can be of help with some kitparts, training or other. |
#8
LabVIEW - easy to learn, lots of knowledge within FRC, has a niche in automotive / manufacturing industries
Java - easy to learn, works well for AP Computer Science students, very popular in general C++ - harder to learn, best performance, fairly popular in general, translates well to other robotics applications (microcontrollers) Last edited by connor.worley : 30-07-2015 at 13:36. |
#9
I second this. The programmer knowing what he (or she) is doing is much more important than what language they use. I would recommend standardizing the team to use one language (even if different students have experience with different languages) because otherwise you will need to re-image the RoboRIO every time you want to change languages. |
#10
I think asking yourself two questions will solve this for you.
Q's:
A's:
#11
I don't have any data, but from what I see the top teams tend towards Java, then C++, then Labview. There are "top teams" proficient in each of those languages however; it really comes down to what the students and mentors are most familiar with.
#12
If your mentor already knows Labview, use that. In any other case I would recommend java. Learning Java will teach kids how a text language works, which should allow them to learn many other languages without difficulty. Also: They should be able to view many of the top team's code and learn from it. (254, 1114, and 971 all used text languages)
#13
A lot of teams are starting to move to interpreted languages (Python, JavaScript, etc) because the new roboRIO has the processing power to handle them. Interpreted languages have numerous benefits, such as no deploy time and the ability to grab code from the roboRIO. If you have a mentor that is able to handle the nuance of doing such than I'd recommend it.
However, if you have no one able to handle an interpreted language than I'd stay with Java or LabView since you will be able to receive support from your friendly neighborhood CSA. |
#14
Another possible approach is to give the students the opportunity to use more than one language if you have the mentor and/or experienced students to support that.
For example you could use C++ or Java for the robot and LabVIEW for the operator controls. That way students get exposure to more than one language so they can determine what they are most proficient in. |
#15
I don't mean to hijack the thread but this reminds me: When my team went to a compile/upload cycle outside of Eclipse we got a pretty dramatic speedup. We found that for C++ the waiting didn't need to be more than a couple seconds.
