Go to Post I am as certain as can be on this issue ... believe me. - Paul Copioli [more]
Unread 08-08-2015, 21:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Smaller shifting cylinder
I'm working on a shifting gearbox design with two gears on the CIM that go directly to the shifting gears. I'm running into an issue where the CIM is too close to the shifter shaft, so I can't easily fit a regular Vex pancake cylinder there. I was going to swap it out for a 3/4" bore round body cylinder, but the mounting nut on that one is too large and hits the CIM. Is it feasible to use a 9/16" bore cylinder in place of the 3/4" bore? According to my calculation its force output is 16lbs compared to the 3/4" bore's 27lbs, but this is also on the first stage of the gearbox so the force required to shift should be less (there's a 2:1 reduction happening after the shifter).
Unread 08-08-2015, 21:40
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Smaller shifting cylinder
We used a smaller shifter cylinder (round), 9/16 in both 2011 and 2012. Going to a smaller cylinder worked great, I think 973 did the same thing (Adam)? Also I recommend just tapping the mount so you can get a better OD/ID ratio.
R.C.
MadTown Robotics Team 1323
Unread 08-08-2015, 21:46
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thank you! That sounds really good.
Unread 08-08-2015, 22:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It should work; you're still getting a better shifting force than with a servo. You may have difficulty shifting while driving hard. Without more specific details on how the shifting is done (e.g. ball, dog, and the anticipated torque and speed of the shaft during the shift) others' experience may correspond to comparing apples to cantaloupes. This is something you will probably just have to try out in driver practice. When you do this test, don't just set up a bare drive chassis; add an amount of weight similar to what your competition robot will have.
If you really like your design otherwise but can't get a large enough cylinder into position, you may be able to move the cylinder farther back along the axis, or move it to the side and use a lever to push/pull the shifter.
Unread 08-08-2015, 22:31
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Back in the earlier AM Shifter days we would put a separate regulator to turn the shifter air down to 40PSI to prevent the roll pins on the shifters from breaking. We never had any problems with the reduced amount of force.
Unread 08-08-2015, 23:49
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
It's a ball shifter, so already there's an advantage force-wise.
I considered using a lever but I wanted to use the Vex shifting attachment.
Unread 09-08-2015, 11:57
AdamHeard's Avatar
Lead Mentor
Used 9/16 bore on traditional wcd 2 speed a few times.
Used 7/16 on swerve, but that was a stage earlier in reduction.
Both were dog shifters.
