Joystick issue
Hi,
I'm relatively new to command based programming. I have code on Netbeans for our team's robot from last year, so it uses the 2014 control system. I have the 2015 driver station and I change it to the '14 DS & FMS so I have comms and robot code. When I plug in a controller (Xbox), the Joysticks box turns green and if I go to the USB devices on the DS, the lights will show up corresponding to the buttons that I press on the Joystick (e.g. 1-A, 2-B, etc). However, when I enable teleop and press buttons, the robot does not respond even though I have specific buttons perform commands. I have already printed out the joystick and button values (-1.0 to 1.0 for joysticks and true/false for buttons) and the joystick values are always 0.0 and the button values are always false, even though I'm pressing them. I don't think it's a code error because I went over it with one of our team's mentors. Any help is appreciated Thanks |
Re: Joystick issue
For example, if you have: Code:
Joystick driveStick = new Joystick(1); I had the same issue and solved it here. |
Re: Joystick issue
Thanks Mitchel Stokes it helped
