Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Unread 27-09-2015, 12:48
ScottRandallWay ScottRandallWay is offline
FRC #2543
ScottRandallWay is an unknown quantity at this point
How to access 2nd Pnuematic Control
Our robot features two pnuematic module controllers. We can access the ports on the first module properly (0-7). I am unclear how to access the solenoids hooked to the second unit. When you create a new Solenoid object one of the constructors takes a module number and a port. I assume I need to use this call and designate the proper module number. Am I on the right track? How do I figure out what the module number is?
Scott
Unread 27-09-2015, 13:53
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: How to access 2nd Pnuematic Control
Scott
Next module will be 1.
Unread 27-09-2015, 15:24
The next module will be whatever address you assign in the roboRIO WebDash: http://wpilib.screenstepslive.com/s/...ribution-panel. A new address needs to be assigned so that it won't conflict with the existing PCM, as both have an address of 0 by default.
