Go to Post Repeat after me: "The Internet is my friend." :rolleyes: - Bill Moore [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 20-10-2015, 17:45
Maninder Sran Maninder Sran is offline
FRC #2935
Maninder Sran is an unknown quantity at this point
[OCCRA]: ROBORIO NOT DETECTED
I am new to programming for FRC and i just wrote my first frc program in java. When i tried to deploy the code i got this error:
[echo] roboRIO not found via mDNS, falling back to static USB
[echo] roboRIO not found via USB, falling back to static address of 10.29.35.2
BUILD FAILED
C:\Users\HP\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
Total time: 8 seconds
How do i solve this issue? And to stress the issue i am new to programming frc so i do not know that much, but i really need this to work before competition this saturday.
Unread 20-10-2015, 20:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: [OCCRA]: ROBORIO NOT DETECTED
I'm probably not going to be the person to answer your question, but I know that those people will need more info, such as:
How is the roboRIO connected? To the D-link, or by direct USB connection to the development platform?
If to the D-link, is the development platform tethered (connected via a network cable) or connecting wirelessly?
How is the D-link configured? What image version is installed, and what IP address does it have? If you're connecting over wireless to the development platform, what is the network name (SSID)?
Finally, how is your development platform configured? What version of what software does it have, and is it configured to use DNS on the port that you're connecting? If not, what IP address is it (and also the D-link) configured for?
Unread 21-10-2015, 08:17
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Also have you imaged the roboRIO as described here?
http://wpilib.screenstepslive.com/s/...g-your-roborio
