Go to Post Boy you guys try to make my job harder every year. - Al Skierkiewicz [more]
Unread 27-10-2015, 10:26
romanvolovoy romanvolovoy is offline
FTC #10532
romanvolovoy is an unknown quantity at this point
[FTC]: Cannot use Legacy (EV3) Sensors
Hello! I have been playing around with the software and sensor setup and was not able get legacy sensors to work!
I defined legacy touch sensor as TouchSensor and the phone was able to find the sensor, but it would always return true in isPressed() function. It would always return false if I unplug the sensor.
Same story with the ultrasonic sensor... Values for distance fluctuate from 0 to 255 and only at times show right values.
I almost gave up on trying to get this sensors to work... If I am doing something wrong, please let me know!
Thanks!!
Unread 27-10-2015, 10:41
JimInNJ JimInNJ is offline
AKA: Jim Bates
FTC #9765
JimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond repute
Re: [FTC]: Cannot use Legacy (EV3) Sensors
Thanks!!
You are correct, that EV3 sensors won't work with the Android system, only the older NXT sensors work. The EV3 sensors use a different communications protocol that the Legacy module doesn't support. Since FTC was never allowed to use the EV3 anyway they didn't include that protocol. So, to sum it up:
The new Android system only supports NXT sensors! Sorry!
