Go to Post It really is disconcerting to hear those chains rattling above your head. I think their effect was psychological more than anything else. - Greg Marra [more]
Unread 31-10-2015, 12:02
StormyStan StormyStan is offline
FRC #5175 (Robo Panthers)
StormyStan is an unknown quantity at this point
Wireless Connection error
We are having an error connecting to our robot using wireless. It works perfectly fine when we are tethered in. But when we try to connect using wireless we get an error saying "Windows was unable to connect to 5175." I have looked everywhere and I cannot find an explanation why only the computer with code cannot connect wirelessly. Another thing to note is that the D'Link is listed as "Unidentified network" when we are tethered in if that is an issue.
Unread 31-10-2015, 12:06
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Wireless Connection error
Are you using a static IP address or dynamic? If dynamic, try changing to a static address of 10.51.75.5 (this will need to be done individually for Ethernet and wifi). It should come up as Unitdentified Network over the tether.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 31-10-2015, 12:13
All I know thus far is that I used the Bridge Configuration Utility tool in the most recent update suite. I'm not sure where to tell if it is static or dynamic or what the tool configured the d'link to.
Unread 31-10-2015, 15:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The question is - how is the driver station computer getting an IP address? It will be in your network setup on that box. If you can't find it, let us know what OS you're using there.
Unread 02-11-2015, 12:11
Sorry for the late reply I didn't have access to the computer. I'm not exactly sure what i'm looking for or where to find it but I am on Windows 7.
Unread 02-11-2015, 13:06
Ari423's Avatar
FRC #5987 (Galaxia)
Look here for instructions to change your IP address. It should be a static IP address of "10.51.75.5". (a.k.a. select "Use this IP address") If it already was something like that (10.51.75.*), try changing it to DHCP and see if that works (a.k.a. select "Obtain an IP address automatically").
2013: Programmer
Unread 03-11-2015, 11:21
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Personally I have found the simplest setup to be using the RoboRIO setup to provide DHCP (which I think it is the default setting) and then making sure that your wireless connection on your laptop is configured to use DHCP as well.
The roboRIO webdashboard (accessible through the USB connection) will show you this:
http://s3.amazonaws.com/screensteps_...2FL2Yl%2Bns%3D
The laptop wireless config should look like this:
The most important part is that they match... either both set for DHCP or both set for a fixed IP address.
Unread 03-11-2015, 12:27
I just checked and they both match but my computer isn't even showing the robot as an obtainable address. I can't try and connect to test if it works because I cannot see the network.
Unread 03-11-2015, 13:15
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Do you mean that you do not see your network (5175) listed when you look for wireless networks to connect to from your laptop?
Unread 03-11-2015, 13:34
Does the list of wireless networks shown by your PC list "dlink" as a possible connection?
(That's the default SSID for the DLink and it will be this if the DLink was reset but not FRC programmed.)
Is the switch on the back of the dlink set to AP 2.4GHz or AP 5Ghz rather than bridge?
(Needs to be on one of the AP settings AND match what your PC wireless supports. All PC's support 2.4GHz, but some do not support 5GHz.)
Are two blue lights showing on the front of the dlink?
(There are three LEDs on the front of the DLink. For normal operation there will be a blue power light-on the left, and a blue AP-in the center.
The right blue Bridge light is usually only for competition field use, so it normally should be off for home use.)
Unread 03-11-2015, 15:05
There is no other connection listed other than my school's network. The Dlink is set to 2.4GHz same as we always set it to. Both the normal operation lights are on. I previously reset the router and imaged it using the Imaging tool included with labVIEW so it should appear as 5175
Unread 03-11-2015, 15:02
Correct when I try to search for the dlink network all I find is my school's network. There is no other network listed.
