Go to Post Vista is like Dave's game hints. They may look good but you really want nothing to do with them... - vivek16 [more]
Unread 16-11-2015, 00:26
J_B_Wood's Avatar
J_B_Wood J_B_Wood is offline
Joey Wood
AKA: Joey Wood
FRC #1389 (The Body Electric)
Team Role: CAD
J_B_Wood is an unknown quantity at this point
Possible to extend output shaft on WCP Gearbox?
Hello,
I am designing a West Coast Drive in which of course the wheels, but also all pulleys are mounted on the outside frame of the robot. This means I need a good bit of shaft space on my gearboxes to mount everything. (Subtract an inch as the shaft passes through a clearance hole in the frame. However, I've ran into a problem and am not sure where to go. On the output shaft of my WCP SS Gearbox (http://www.vexrobotics.com/vexpro/mo...es/wcp-ss.html) I have mounted 2 15mm pulleys, and need to fit a wheel on the end, but the axle is not long enough. Is it possible to order an extra long output shaft/swap it out for a custom-cut piece of hex shaft from our stock, or should I ditch the gearbox I'm using all together and find something with a longer shaft?
On the page I linked, it says the "extra long shaft" can be cut to length, but it seems that is still too short. Any ideas?
Unread 16-11-2015, 00:34
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Possible to extend output shaft on WCP Gearbox?
The WCD version of the gearbox should be able to fit your pulleys and a wheel on the end.
It's a rather simple part to make on the lathe, so it's definitely possible to make your own.
Unread 16-11-2015, 00:39
J_B_Wood's Avatar
Joey Wood
AKA: Joey Wood
Team Role: CAD
Thank you for the response, Asid. Our team does not actually have a functional lathe at the moment, so I'd rather try to find a pre-made solution. I am using 1.5" thick Colson wheels, and 30mm of pulley thickness total, and it does not fit on the part I downloaded. Does the actual shaft come longer than represented in the CAD?
Unread 16-11-2015, 00:42
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I would assume not, but I haven't checked.
Would it be possible to use 9mm pulleys instead, or 7/8" wide colson wheels? Have you though about using chain instead of belts?
The end is tapped for 1/4-20s, so it might be possible to stick a 1/2" Vex tube axle on the end and throw a 1/4-20 on it.
Unread 16-11-2015, 00:43
Knufire Knufire is online now
You should be able to make an output shaft for this gearbox with just a piece of hex or Thunderhex stock. However, you will need to replace the 1/2" round bearing on the motor plate with a 1/2" hex or Thunderhex bearing, and add some method of stopping the shaft from sliding out (shaft collar or a bolt+washer in the end of the shaft).
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-11-2015, 00:51
J_B_Wood's Avatar
Joey Wood
AKA: Joey Wood
Team Role: CAD
Asid: I'm a little weary of using 9mm belts to transmit power to the outer wheels, but it would give me plenty of space. Is there any risk of the belts breaking if I go down a size? I could try smaller wheels, that seems like a pretty elegant solution.
Unread 16-11-2015, 14:08
InFlight's Avatar
InFlight InFlight is online now
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Assuming 5M HTD Belt; the Tensile Strength of the 9mm width belt is around 780 lbs. Provided you use reasonably sized pulleys and don't over tension it, 9 mm belt should be fine in this application.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 16-11-2015, 16:04
Chris is me's Avatar
AKA: Pinecone
You can definitely screw this up, and several teams have had failures using 9mm belts and 24T or smaller pulleys in the drivetrain. If you're not sure I really would go 15mm.
That this gearbox doesn't fit two 15mm pulleys is one of the reasons I haven't used it. It's a lot of space to ask for, true.
Unread 17-11-2015, 11:30
InFlight's Avatar
AKA: Jim
Use of small pulleys really decreases the torque rating of these belt drives. Compared to a 36T pulley a 24T is about a 53% reduction in capability, while a 22T is down to ~47%.
A 15 mm wide belt is 40% stronger than a 9 mm belt. The extra strength may help some, but it is still poor compensation for a bad design.
For smaller pulley sizes, it would be better to go down to a 3M belt since you would have more teeth in contact and there would be less of torque rating decrement.
I would encourage everyone designing belt drives to take some time and understand the product, and engineering equations involved, before slapping it in to their design and hoping it will work.
Unread 17-11-2015, 12:56
AKA: Pinecone
How is going to a 40% stronger belt "compensation for a bad design", but going to a 47% stronger pulley size the proper decision? They seem to both fix the problem about the same, it's just horizontal space versus vertical space which is design dependent.
I've built several belt drives - 15mm wide belts and 24T pulleys on a WCD with 4-6" wheels have been completely issue free for us. 9mm/24T has not treated us as well. I don't see this as a bad design decision to use wider belts when we don't have the clearance for bigger pulleys.
Definitely look at the formulas and understand the rating for each belt - and then also remember that the resources specified by the manufacturer are generally for machines with 20x the run time of the average FRC robot, so you can go a bit closer on the safety margin than you might expect.
Unread 18-11-2015, 04:15
InFlight's Avatar
AKA: Jim
You have a Design choice of v belts, synchronous belt, poly cord, and chain.
Using 5M HTD belt on small pulleys with only 12 teeth engaged and the small 1.5" turning diameter is not the intended or recommend use. The fact that you broke 9mm wide belts, suggests you probably were just getting by with 15mm belt with very little margin.
These HTD belts have some elasticity which reduces the effective number of teeth in mesh on the pulley. This effect is magnified when the number of total teeth is under 30.
Going to a 3M belt would provide additional margin at a given pulley diameter, as there would be more teeth engaged.
Unread 18-11-2015, 07:35
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
SDP-SI recommends a minimum of 6 teeth engaged and has a correction factor for less engagement: http://www.sdp-si.com/D265/PDF/D265T146.pdf
Going to 3mm belt has a significant reduction in strength. Belts are recommended to be used at 1/15 of their breaking strength (http://www.sdp-si.com/D265/HTML/D265T042.html)
3mm HTD breaking strength http://www.sdp-si.com/D265/PDF/D265P1023.pdf
6mm = 213 lbs.
9mm = 320 lbs.
5mm HTD breaking strength http://www.sdp-si.com/D265/PDF/D265P1027.pdf
9mm = 640 lbs.
15mm = 1068 lbs.
3mm HTD working strength (1/15 of breaking strength)
6mm = 14.2 lbs.
9mm = 21.3 lbs.
5mm HTD working strength
9mm = 42.6 lbs.
15mm = 71.2 lbs.
You can probably get away with more than their recommended 1/15th reserve, but that would require some testing and development.
Unread 19-11-2015, 06:04
Marcow Marcow is offline
AKA: Marcus
Rookie Year: 1900
Marcow is just really niceMarcow is just really niceMarcow is just really niceMarcow is just really nice
9mm belts are great, but as Chris said can easily get messed up if you're not sure what you're doing. We ran a very successful 6wd where the middle wheel used a 15mm pully that held two 9mm belts going to the outer wheels. Its just another option. If it doesn't feel safe to you, stick with the 15!
Unread 16-11-2015, 00:53
J_B_Wood's Avatar
Joey Wood
AKA: Joey Wood
Team Role: CAD
Just figured out how to quote. That's neat. And this seems like a pretty good solution, I will try it if I can't find a fix within the stock gearbox.
