| View Poll Results: What is your favorite feature of the SD540? | |||
| Light Weight |
25 | 20.33% |
| Low Cost |
47 | 38.21% |
| Multi-Bank Option |
31 | 25.20% |
| I do not like this product. |
47 | 38.21% |
| Multiple Choice Poll. Voters: 123. You may not vote on this poll | |||
SD540 Motor Controller
The SD540 Motor Controller is now shipping! A seemingly weightless, low cost solution with great functionality is now here and ready to order.
We had great feedback at the recent FRC workshop in Richmond, VA. Many local teams got a chance to experience using the SD540 Motor Controller first hand and witness its amazing control. Product page Specs Performance Testing |
Re: SD540 Motor Controller
Do you have a CAD model of the controllers? I looked around the website but didn't find them, I'd like to add them to our CAD library.
Why are the dip switches on the bottom of the unit, seems like it would make it difficult to adjust once they are on the robot. |
Go to the product page, and click on the download tab on the left hand side of the page.
My 2 seem fine, thanks!
Thanks, I thought I looked there but I guess I missed it.
Quick question, does having a higher output frequency cause any sort of performance difference?
#7
SD540 Motor Controller Comparison
See how the SD540 Motor Controller compares with the other FRC controllers available:
![]() The majority of the information on this chart has been taken from the comparison chart form REV Robotics. See their chart here: http://www.revrobotics.com/wp-conten...6132225162.jpg Similar charts can also be found in Talon SRX, Victor SP, Victor 888, Talon SR, and Jaguar documentation. Last edited by mindsensors.com : 24-11-2015 at 12:39. Reason: To give credit to REV Robotics comparison chart. |
#8
Re: SD540 Motor Controller Comparison
Not to be a buzz kill but did you guys just copy the data complied by REV for the Spark? Even the disclaimer is the same.
#9
I would compare this to the Spark or Victor SP. In terms of weight it beats both, is only $5 more expensive than the Spark, has a limit switch input, and has a thinner form factor than the Spark (although not as flat as the others). The output frequency is also higher, although I'm not sure what effect that has.
The banking option looks handy to slightly lower the cost and use less mounting hardware. Looks pretty neat, overall! We would buy them if not for the twenty Talons we already own. ![]() |
#10
Higher switching frequency will make thing more efficient, and power delivery will be continues rather than discrete. In other words better linearity and smooth operation.
#11
I'd like to know how the upgradable firmware works. Can you shed any light on that?
#12
Since this controller is currently only a PWM device, we will release a device to perform the firmware upgrade. All you have to do is connect it and change it to bootloader mode with the dip switches. More information will be available once the device it released.
#13
Emphasis added... are there plans to enable other communication methods line CAN? Possibilities or plans to interface this with encoders in the future?
#14
We are planning on implementing CAN on future models. Possibly as a single board swap out kit. The firmware upgrader will actually use I2C that is already implemented for bootloading the device.
#15
What does "multi-bank" mean? I see nothing on the web pages that gives me even a hint of a clue. The price sounds pretty good, but perhaps if I understood what "multi-bank" means it would actually be worth buying.
