pic: 2823 Offseason WCD Test Chassis
Re: pic: 2823 Offseason WCD Test Chassis
At first glance I thought you used some kind of staple to hold the frame together.
In any case, Looks nice. Good job! |
Nice job for your first attempt! A few minor points to make the system better.
First, if your chains were to break you would need to remove either your front or rear rail to access them. As of now that may not seem like a big deal, but once you have electronics and a superstructure added to your robot it will become increasingly more difficult. Take a look at the chassis on our 2014 robot, we use internal belts, and we leave the tube ends open to have access. ![]() Secondly, have you considered using gusset plates on the top of your rails to connect them instead of the aluminum angle? You could use VEX pro parts, or make your own. You could just match drill them if you do not have access to a mill. I think that a gusset plate and rivets will create a stronger connection than the angle in the corners. I hope this helps! |
We redesigned the system in 2012. We use 1 1/2" x 3" Tube - we use two 15mm belts in the same path that chain would take. We make custom pulleys that fit inside the tube. We buy the pulley stock from SDP/SI The pulleys are 1.200" long with a 1/2 hex broach. We don't need a flange because the tube keeps the belts on the pulley fine. We also offset our axle bearings with .125 plate so that the inside of the bearing is flush with the inside of the tube. Last edited by Sh1ine : 05-12-2015 at 09:19. |
#7
Keeping the ends of your tubes open is a plus. If not, consider attaching the front/back tubes & bellypan with bolts for cleaner access. Rivets can be faster to drill out and replace compared to a bolt/nut but having the variable of aluminum shavings flying around your robot in the middle of a crisis repair isn't worth the few seconds in most cases. 3467 ran a Chain in Tube running our elevator last year (the layout was identical to a 6wd setup like this one) and having the ends open made the single repair/adjustment we made to the chains after assembly not as painful. Someone (*cough* me *cough*) accidentally pulled the center output shaft on the practice robot. |
#8
The problem I see is, where do you install the RivNuts in the tube to where you can still remove and replace the chassis rail internals without running into the RivNuts? If it were a rivet, you just drill out the rivet to remove the tube, which also removes the obstruction in the tube.
#11
Looks great, not bad for a first time chassis build.
My only question is, why are you using the WCP SS Gearbox in the WCD configuration when you're doing chain-in-tube? Using the standard configuration would save you almost an inch of space on each gearbox (and also reduce gearbox cantilevering due to motor weight). |
#13
One of the things that I noticed is your belly pan appears to be attached directly to the bottom of your rails. We did this a couple of times and the screws eventually came loose and the belly pan dropped out of the bottom.
I would make sure that you have plenty of support especially around the battery. You could possibly attach some angle brackets (like in your corners) and mount the belly pan to them. Also, does your cutout for the gearboxes have enough clearance to remove them without dropping the pan out? |
#15
