Go to Post I may be an engineer, but I am not smarter than a 5th grader. - Josh Drake [more]
Unread 03-07-2002, 13:54
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
emulationFIRST v0.04
Hopefully this will be the last of the release-a-day builds. I think I've fixed the crashing problems. If they still persist, please send me whatever output information you can get from them. As well as fixing bugs, this release also should fully support EEPROM (via DATA, READ, and WRITE commands). I want to check and make sure that EEPROM is accessed on a per program slot basis (ie each program slot has its own slice of EEPROM and can't access the EEPROM of other program slots). That is how I implemented it. There also is some support for the DEBUG command but it's not complete by any stretch of the imagination. Please test it out and send in bug reports.
As always, available here:
http://www.rit.edu/~msl8101/emulationFIRST/
Matt
(And yes, I did update the links this time ).
Unread 03-07-2002, 14:08
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
is it a bad thing if i get a big error message (from windows) that emualtionFIRST has failed and had to be shut down? it seems to work with the default code, but when i tried it with the code from the robot, which does include EEPROM access, it seems to horribly fail. any ideas?
AIM --> Woloi
Email --> ian@woloschin.com
Unread 03-07-2002, 14:17
Yes it's a bad thing. If you send me a copy of your code, I can try and figure out where emulationFIRST is dying. There are probably numerous bugs throughout the code and it just needs various test cases (aka code segments) to test it out.
Matt
Unread 03-07-2002, 15:49
College? What?
well, the strange part is, it breaks when it's parsing the code. i hit enter and it died. and the robot code isn't all that readable, cause me and dan (more me i think) were somewhat lazy this year. if you want it though, give me your email and i'll send it.
AIM --> Woloi
Unread 03-07-2002, 22:52
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Wink Gettin' Better
Here's what I see when I run this year's BeachBot code through it:
C:\Robots\2002\FloridaFiles\BeachBotSW\2002-April-26\Processed>EmulationFIRST BeachBot2002.bsx BB2002MainLoop.bsx BB2002OutputData.bsx
Error: parse error.
Parse error, line: 444.
Error with line:
   for temp2=1 to temp1
Error: parse error.
Error with line:
Error with line:
SError: parse error.
Parse error, line: 574.
Error with line:
 if not (IN3 = 0) then SPPL0000
Error with line:
Error with line:
Error with line:
Error with line:
Input Values:
oi_swA=
Unread 08-07-2002, 10:55
I can tell you that the first part of your errors is because for loops aren't implemented. I'm not too sure about the second part but I think it may be because I haven't included IN3 as a variable/reference. Hopefully I'll fix both of those for the next release.
Matt who's back from Indiana finally
Unread 08-07-2002, 23:37
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
does your emulator have to be run with the FIRST stamp code or can it handle any pbasic program? E.G. the one I posted in another thread...
Unread 09-07-2002, 08:54
Unfortunately it only works with code designed to run on the InnovationFIRST controller. It doesn't really do anything with pin outs etc.
Matt
emulationFIRST v0.09 Matt Leese Programming 4 18-07-2002 14:36
emulationFIRST v0.03 Matt Leese Programming 7 03-07-2002 13:00
emulationFIRST v0.02 Matt Leese Programming 3 02-07-2002 16:37
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
