pic: 2015 Off-season Single Speed Coaxial Swerve Chassis
Re: pic: 2015 Off-season Single Speed Coaxial Swerve Chassis
Is there a hidden electronics pan, or was it just not CADed? The design is certainly interesting.
There is a polycarbonate panel in the center for electronics, though it has not been populated in the CAD model.
I always love seeing the swerve designs your team comes up with
Can you show a closer view of module?
and discuss what metrics you (Nick) are going after? Love PWNAGE swerves. an also always like the bevel edge bumpers. |
Why did you go with a 775 on the VersaPlanetary for module rotation? What ratios are on it/speeds can this achieve?
#7
We have used 5XX series motors on both our 2014 and 2015 swerve drives for steering. I'm not sure why Nick used a 775, we have never had an issue with the 5XX series motor for steering. I am guessing it is because we had Nick setup our Versaplanetary gearbox in Solidworks with "Configurations" and he picked a different configuration. To discuss configurations a little more. When designing the robot we can insert a Vex Versaplanetary gearbox into Solidworks and change it to any possible configuration. This is a tab that allows you to reconfigure an assembly automatically, once you've spent the time adding in all possible parts. You can hide ,surpress, change items in the assembly so that it "reconfigures" the assembly. We currently can change between single and double stage reduction. We can change between the Bag motor, RS550 and RS775 motors. We can change the output shaft options between the .375" hex, .500" hex, .500" round, and 8mm keyed CIM shaft. We can also change to a dual motor option. This all occurs with a click of a button on the same gearbox assembly. So there is no deleting and reinserting a new custom setup. There is no creating a custom assembly each time we need to insert a VersaPlaentary gearbox into the robot design. We should create a video sometime to show how to do this for the First community. |
#8
I have some decent renders that show things pretty well, so I'll see if I can get those up here. |
#9
Here are a couple renders that show things a bit better.
![]() ![]() Feel free to ask any questions. Keep in mind that there were/are still things I would want to improve on this design, I just found a stopping point and had some other projects I wanted to hit before the new season begins. Sorry for the large images. |
#10
Very nice swerve module, it is nicely packaged. I am really impressed that the motors are stationary in this design. I feel ignorant, but what separates a swerve drive from a coaxial swerve? What size wheel are you using and what are the drive gear ratios? Are all the gears stock? How much does the module weigh?
#11
Also, can you explain how the bearing surface works between the wheel module and the rest of the drive module?
#12
Also, the wheels look to be 4" diameter, based on a 2.5" diameter CIM. |
#13
+1 to sharing the file and/or a video making it. |
#15
