Go to Post Is it really only 5 axes? It looks like that thing could bend time and space. - EricVanWyk [more]
Unread 09-12-2015, 12:54
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Convert project from cRio to RoboRio?
My team has a Labview project written for a robot that had a cRio.
We'd like to use a RoboRio to develop code and teach programming with.
The saved project was built for the cRio. Is there an easy way to convert an existing LabView project? What's an efficient way to do it other than make a new project for the RoboRio and start copying piece-by-piece?
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 09-12-2015, 16:38
Re: Convert project from cRio to RoboRio?
Open your project.
Right-click on the top row -- Project XXX.lvproj and select New >> Targets and Devices.
In the dialog, add a roboRIO ( either existing or by type).
Drag the VIs from the cRIO target to the roboRIO.
Right-click on the target, open the Properties dialog and set the IP or name.
Right-click to remove the old target.
Greg McKaskle
Unread 09-12-2015, 17:04
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Originally Posted by Greg McKaskle View Post
Open your project.
Greg McKaskle
Will that automatically update the code (read WPILib) to work on the roboRIO?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-12-2015, 17:14
The code links to WPILib code. Changing the target type from cRIO to roboRIO or simulated will link to different libraries and will allow for conditional compilation where needed.
This will not update channel constants, and in particular, cRIO I/O was 1-based and roboRIO is 0-based. So depending on how you make PWM and other electrical connections to the roboRIO, you may need to change those. But generally, yeah. It will either run or will tell you a few things that broke.
Greg McKaskle
Unread 11-12-2015, 10:23
Doc Wu's Avatar
AKA: Al Gritzmacher
Thanks Greg, that's exactly what I was looking for!
