pic: 649 Offseason Hexagonal Chain-in-Tube WCD
Re: pic: 649 Offseason Hexagonal Chain-in-Tube WCD
Very neat. I assume the bumpers will form the hexagonal sides? Very clever, and it performs the same function.
What made you opt for screw+washer and eclips to secure the shafts over circlips everywhere? Is it just me, or are there 4 wheels on the far side and only 3 on the close side? EDIT: Did you add any extra spacing for the chain? Apparently that's a problem according to these tests. |
Chain spacing is .1835 for the 6W config and .2 for the 8W config (cuz both designs share the outer holes, we couldn't make everything a nice .186 like we would have liked) |
EDIT: just read the original post lol... |
Going by the 2014 rules (as well as 2010-2013 I believe, don't quote me) the bumper corners need to be supported. Because there are unsupported corners that overhang the wheels this drive base would not pass inspection in 2014.
Cool design otherwise. |
I'm not sure what's going on the bumpers, but we will definitely take that into consideration.
Meanwhile, we have uploaded a .STEP file to grabCAD for anyone who wants to see this drivetrain closeup on their CAD software. Link is found here: https://workbench.grabcad.com/workbe...3ckfPNf6IoZmc9 |
#7
Assuming 2016 game rules are similar to 2014, you can just have plates that touch the bumper in the corners for the required distance (1/2" in 2014 IIRC) to satisfy the bumper rules.
#8
I think that is a nice design especially with the option for both 6 and 8 wheel drive. I was wondering why your side bumper supports are oriented horizontally instead of vertically. Additionally, it is pretty easy to cut a hole in the top of your change (where the chain is running) and put in a basic chain or belt tensioner if your end up having that problem. In the past, I have found 3D printer parts with a bolt to be great for tensioning.
#9
Since the bumpers have to be 2 inches off the ground according to 2014 bumper rules, the bottom half of the boxtubing wouldn't actually contact the bumper. so we turned it sideways to get some more contact area. But the bumper system is still a work in progress, so we may change it again if we think of something nicer. and actually the design can be used with versablocks if we need to (the drop center is the same). we are just hoping to avoid spending money (and robot weight) on them. |
#10
I believe you will also be able to get a 4wd out of that system too!
#11
Is this slightly better at turning due to the wheel that is on the outside (wider track width)
#12
Also, one time I saw a 4wd FTC chassis, and when it turns the entire thing shook, and I think that was because of the rubbing of the wheels. I think if we use a 4wd on this drivetrain, we will see the same thing happen, although I am not entirely sure. |
#13
why aren't the two gearboxes parallel?
