Installation Problems
I've been having a lot of issues installing Solidworks on my home computer. The installation worked fine on my laptop, however I keep running into issues with installation my desktop. The first problem I ran into (I don't remember the first error message/number) was the installer's installation of C++ 2005 Redistributable. I eventually had to disable .NET Framework 3.5.1, restart my computer, and enable it again. I was able to then manually install C++ 2005 Redistributable, and Solidworks proceeded fine installing the rest of its needed software, excluding the program itself. I am now having an issue with the installer installing Solidworks itself. This first happened at 27% complete, and now at 11% complete:
Internal error: The Windows Installer for this product component did not run as expected: Register_DocMgrDLL.9FB)7B3D_OB7D_4A2F_82AB_F16B1F2 4912C. Contact Technical Support. I have a feeling this may be related to my unsuccessful attempt at updating to Windows 10. I was able to boot into Windows 10, but after one reboot, the computer hung and would not boot. Luckily, Windows 10 rolled itself back into Windows 7, but I had issues my USB drivers and port not working after first rolling back. The only solution I've found online was to manually install MSXML and the newest version of .NET Framework, but it hasn't fixed my problem. I have the installation logs if it will help. I appreciated any help! Here's a snippet from the logs. I've tried Googling this, but nothing seems to be working. "Action start 15:33:56: InstallFinalize." 15:34:37 Error Status 157 0 " SW MSG: WI_GetProperty: CustomActionData = C:\Windows\;$C:\Program Files\Common Files\;$ (0)" 15:34:37 Error Status 157 0 " SW MSG: WIDll_RegisterDocMgrDlls: CustomActionData is C:\Windows\;$C:\Program Files\Common Files\;$" 15:34:37 Error Status 157 0 " SW MSG: WIDll_RegisterDocMgrDlls: szExeName = "C:\Windows\Microsoft.NET\Framework64\v2.0.50727\r egasm.exe" "C:\Program Files\Common Files\SolidWorks Shared\dimxpert.dll" /codebase /silent" 15:34:37 Error Status 157 0 "CustomAction Register_DocMgrDLL.9FB07B3D_0B7D_4A2F_82AB_F16B1F2 4912C returned actual error code 3 (note this may not be 100% accurate if translation happened inside sandbox)" 15:34:37 Error Status 157 0 "Action ended 15:34:19: InstallFinalize. Return value 3." 15:34:37 Error Status 157 0 " SW MSG: WI_GetProperty: CustomActionData = 6;$C:\Windows\SysWOW64\;$C:\Windows\system32\;$C:\ Windows\Microsoft.NET\Framework\v4.0.30319\;$C:\Wi ndows\Microsoft.NET\Framework64\v4.0.30319\;$SOLID WORKS 2015;$ (0)" 15:34:37 Error Status 157 0 "CustomAction RollbackUnReg_DocMgrDLL.9FB07B3D_0B7D_4A2F_82AB_F1 6B1F24912C returned actual error code 3 but will be translated to success due to continue marking" 15:34:37 Error Status 157 0 "CustomAction RollbackUnReg_DocMgrDLL.A48C1CF2_EBF8_48E8_ACAD_68 CA04F776A2 returned actual error code 3 but will be translated to success due to continue marking" 15:34:37 Error Status 157 0 "Action ended 15:34:36: INSTALL. Return value 3." |
