Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
Unread 05-01-2016, 16:26
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
pic: 775pro Arm Gearbox
Unread 05-01-2016, 16:32
Billfred's Avatar
Billfred Billfred is offline
Re: pic: 775pro Arm Gearbox
Looks sharp! I like the gear-in-tube approach.
One alteration that may help you assemble it more easily, at the expense of more machining work: We used thin pieces of metal to retain the bearings in place in 2009. I'm not sure if they were riveted or we tapped the holes, but you can kinda see it at the top of the robot in this full-res picture. Might be something to consider.
Unread 06-01-2016, 10:37
FRC #0610 (Coyotes)
That's a good idea. There are obviously many ways to retain the bearings, and if we actually make this gearbox, I may stick with our usual approach of turning the ends of the shafts down and putting retaining rings on either end.
Unread 07-01-2016, 19:39
Dival Dival is offline
AKA: Yarden
FRC #3316 (D-Bug)
Team Role: CAD
Dival is an unknown quantity at this point
Looks great!
I wonder what is the benefit of such gearbox in comparison with some kind of two planetary gearbox configuration with the same rate. Any help?
Also, where do you plan to get the first stage gears from?
2014 Israel Regional Winners! (Special thanks for team #1574 - Miscar and team #3065 - Jatt)
To come up with a complex solution to a complex problem is hard; to come up with a simple solution to a complex problem is even harder; but we both know what makes more fun.
