Go to Post You can also always use the "Report Post" button on each post and that'll dispatch a carrier pigeon to each of our homes...or an e-mail if the carrier pigeons have taken the day off. - Madison [more]
Unread 07-01-2016, 00:29
Liquid_Science Liquid_Science is offline
FRC #2996
Liquid_Science is an unknown quantity at this point
Team 2996 Offseason Octocanum Project
https://drive.google.com/open?id=0B3...Wx3YkM2SVVXcVk
https://drive.google.com/open?id=0B3...HhoZEJYMVRGeFE
Team 2996's first octocanum prototype! I was inspired by team 4265 last year with their beautiful chassis and wanted to create our own octocanum drive that might prove useful.
CAD: All the auto desk inventor parts are in the link below. There are also most of the imported components as well, with the exception of the Vex 18T timing belt pulley that goes on the inside of the modulus (there is a clear space). For those of you running a different cad program, there is a completed step file of the chassis as well.
*Note: The electronics in the CAD are more for show then anything else. Its no where near the layout we ended up going with.
Full CAD:
https://drive.google.com/open?id=0B3...jZWMHFGZEViMzg
Design Notes:
-The inner chassis piece is designed to be used with either a tough box mini or a Vex Pro ball shifting gearbox. Both sides of the piece have the appropriate holes.
-The belts used are 70T Vex 9mm belt; pulleys are 18T Vex timing pulleys.
-The pistons used are bimba FS-171-1N. They have just enough actuation to switch between the two types of wheels. This can be changed with the size of the piston, and some slight modifications to the chassis.
-Most importantly, we managed to get the weight to just around 54lbs including all the electronics, pneumatic, ect.
Just as a side note: If any team has a similar design, we need some help coding this thing and don't really know where to start.
I am super excited for this project, and welcome any questions, comments, and critiques! Also, this is my first time posting to Chief Delphi, so if something does not work, let me know and ill try to fix it.
Unread 07-01-2016, 00:34
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Re: Team 2996 Offseason Octocanum Project
We ran octocanum on our competition bot last year -- here's the robot code, and the drive code.
I'm also getting an 'access denied' message with your links...maybe check the sharing settings?
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 07-01-2016, 00:43
FRC #2996
Thanks for the code!
The links should work now, just had to change the sharing setting on google docs.
Unread 08-01-2016, 15:09
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Sweet! I can't wait to take a look at the CAD files.
"The systems... They DON'T INTEGRATE!"
