Go to Post The mission is to mobilize community, school and corporate resources to support the vision. The method is to provide an interesting, exciting program that gives young people opportunities to explore and expand their capabilities and interests. - Rick TYler [more]
Unread 07-01-2016, 20:06
richtop richtop is offline
AKA: Richard Topolewski
FRC #5053 (Laker Robotics)
richtop is an unknown quantity at this point
Java Code Release with Easy Motion Control
Including easy to use Motion Control for Java (well I think it is easy, at least that was the intent).
2016 Start Java Code
https://github.com/LakerRobotics/FRC2015Java.git
  • Includes an easy to use Motion Control to drive in a straight line. It allows you to specify the distance, a max-speed and a ramp-up/ramp-down zone. It includes Gyro controlled straight line adjustment. Compatible with WPI's Robot Builder.
  • Includes an easy to use motion controlled turning. Controls speed of rotation using a gyro, again with a ramp-up/ramp-down zone and a maximum speed of rotation. Compatible with WPI's Robot Builder.
Unread 07-01-2016, 20:40
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
Re: Java Code Release with Easy Motion Control
Cool stuff!
You should add that description to the readme on Github - makes life easier.
Also, why all the temp files? You should gitignore those.
Unread 08-01-2016, 00:18
Thanks for the kind words.
Ya the ~ Temp files is kind of embarrassing. I did add *~ it to the .gitignore file, after I saw the ~ files, but the original ones had I to be removed. It has been cleaned up.
I also added some description to the readme.md file as suggested.
