Go to Post There's something about building a robot that just makes people enthusiastic about life. - BBnum3 [more]
Unread 08-01-2016, 19:59
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
Xbox Controller Class V2
I have been playing around with some of my last years code and decided to revise the XboxController class.
The major changes in this version are that it no longer uses the Joystick class, it now supports commands, and it now checks if the sticks are in the user defined dead zone.
I have also not yet been able to remove the refresh method which is necessary for the changedUp and changedDown variables on each of the buttons in order for them to change only once per run.
https://github.com/FRC3571/2015TestB...ontroller.java
Just a couple of small warnings.
I am confident that this code works but it has not yet been tested.
Also just like my last years code it only gets the current values for everything after the refresh method has been called.
