Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
Unread 09-01-2016, 17:52
rajkarthikkumar rajkarthikkumar is offline
FRC #5465
rajkarthikkumar is an unknown quantity at this point
Grappling Hook?
Is there anything in the rules that prevents a grappling hook from being used during the last 20 seconds?
Unread 09-01-2016, 17:59
cait.schroeder's Avatar
cait.schroeder cait.schroeder is offline
AKA: Caitlin
FRC #6601 (Easy Company)
Rookie Year: 2015
cait.schroeder is an unknown quantity at this point
Re: Grappling Hook?
As I have grasped, there is nothing in the rules preventing it, my team was actually joking about it as we have a "grappling hook gun". It just says the dimensions and how it is built to support scaling robots. My team has not talked about scaling yet but I am opposed to the idea because of the possibility of damaging the robot.
Unread 09-01-2016, 18:00
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Re: Grappling Hook?
No rule against it. any type of rope or cable might be considered a "entanglement hazard" though... so you'd have to be careful of that.
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 09-01-2016, 18:30
Spen-curr's Avatar
Spen-curr Spen-curr is offline
Dancing Squid
AKA: Spencer
FRC #2605 (Sehome Seamonsters)
Team Role: Mascot
Spen-curr is an unknown quantity at this point
Re: Grappling Hook?
A hook would be pretty cool, but I think that the options presented in the video are more reliable.
Unread 09-01-2016, 18:31
Re: Grappling Hook?
I would use caution, and pay attention to the safety rules. I don't think it would be illegal just because it's a grappling hook, but the exact methodology should be considered carefully.
Unread 09-01-2016, 19:24
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Re: Grappling Hook?
If the hook misses, and lands more than 15 inches from your robot, that would be a violation.
Unread 09-01-2016, 19:26
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
Re: Grappling Hook?
The problem with the use of a grappling hook, is that the goal opening is very near to the bar you use to climb, so if you miss your hook may be caught on the goal opening, and that could cause problems because a) you couldn't climb and B) at the end of the match you would have to figure how to get that hook down
Unread 09-01-2016, 20:35
josh_marcy josh_marcy is offline
FRC #2199 (Robo-Lions)
josh_marcy is an unknown quantity at this point
Re: Grappling Hook?
Also if you miss, you are in violation of G12. The manual also says that in that situation, you can be assigned an additional yellow card for egregious robot behaviour.
Unread 09-01-2016, 20:39
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Re: Grappling Hook?
The real question: 3 prongs or 4?
Unread 09-01-2016, 21:26
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Grappling Hook?
I don't see how that would be the case unless your hook sticks in the floor. It should be entirely possible to design to prevent that.
Does anyone else remember when TBA signatures actually worked?
Unread 09-01-2016, 21:33
Dhill098 Dhill098 is offline
AKA: Damian
FRC #2383 (Ninjineers)
Team Role: Driver
Dhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to behold
Re: Grappling Hook?
G12 The following actions are prohibited with regards to interaction with ARENA elements (items A-E
exclude any DEFENSE, RUNGS, and BOULDERS)
A. Grabbing
B. Grasping
C. Attaching to (including the use of hook-and-loop tape against the FIELD carpet)
D. Grappling
E. Hanging
F. Becoming entangled
G. Damaging
Violation: FOUL. If the Head REFEREE determines that further damage is likely to occur, offending
ROBOT will be DISABLED. Corrective action (such as eliminating sharp edges, removing the
damaging MECHANISM, and/or re-Inspection) may be required before the ROBOT will be allowed
to compete in subsequent MATCHES.
According to this, I believe it's perfectly legal if it is a success.
Unread 09-01-2016, 21:57
RoboChair's Avatar
AKA: Devin Castellucci
Re: Grappling Hook?
15 inch maximum extension beyond your frame perimeter still applies. You can just extend to an infinite height.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 11-01-2016, 23:06
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Grappling Hook?
We've played around with some grappling hook ideas for past games, although none have ever actually made it onto the robot. If you can, try finding someone from 1592, who designed grappling hook can pullers for last season. They were pretty cool. We may still have the CAD for some 3D printed claws that close on impact around a bar (basically, once the bar hits something inside the grasp of the open claw, the claw closes around the bar), if you might find that helpful I'd be happy to see if we can dig up the files and send them to you.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
