Go to Post By "resources" do you mean money (sponsor or school), school support or permission, build facilities, or mentors? All of these require different solutions. - Carol [more]
Unread 09-01-2016, 20:05
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Swerve Drive in Stronghold
In the past few years, our team has gotten quite comfortable with swerve drive and were hoping to use it again this season. However, with the complex field elements and unforgiving terrain, I fear that swerve may not be the best option.
Are there any other teams that are considering a swerve drive? Or do you feel that such a drive system is inherently weak in this kind of game?
Head Programmer / Driver
Unread 09-01-2016, 20:11
brickleberry's Avatar
brickleberry brickleberry is offline
Nate Brick
FRC #1507 (Warlocks)
brickleberry is an unknown quantity at this point
Re: Swerve Drive in Stronghold
We have been prototyping a swerve drive system during this past offseason but I don't see a specific advantage to using it in this particular game.
Unread 09-01-2016, 20:19
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
We are. you have a choice of two drive systems this year. tank or swerve, everything else is a waste of time(maccanum, omni).
a tank with treads will be the easiest way to deal with defenses, but will suffer compared to swerve since it can't move sideways. this may or may not be desirable depending on what your game strategy is. We plan on scoring balls in the high goal so to be able to precisely aim and out maneuver any potential defensive robot, swerve is the choice for us. If you plan on being a defense tackling robot than your choice is probably better served by tank.
Most tanks will suffer due to how their frame is setup though(KOP chasis included). so you still need to put a lot of work into making sure you can properly navigate the obstacles
Unread 09-01-2016, 20:30
GKrotkov's Avatar
GKrotkov GKrotkov is offline
AKA: Gabriel Krotkov
FRC #1712 (Dawgma)
GKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud of
I don't think that swerve is inherently weak in this game. I do, however, think that it would limit your options. That's a choice you could make - but it's important to make that choice with your eyes open.
If you intended to use your (pretty awesome) swerve drive once again, you could consider focusing on tower damage and scoring boulders, while using the low bar to get from the neutral zone to the offense zone. Most likely, the defenses in category B and D would be impenetrable to you, but I'm sure there are other ways around the other categories of defenses.
In fact, being able to go under the low bar could help you a lot; note that the defenses in category C seem to be "open-from-behind" defenses. You could be a robot that helps their alliance get through those particular defenses, because you can get over to the other side more quickly.
Unread 09-01-2016, 20:47
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
You can always build swerve with 8" pneumatic wheels....something like this https://www.youtube.com/watch?v=jAqA2OztnpE
Thank you to NASA Robotics Engineers AKA FRC118 Mentors.
Unread 09-01-2016, 20:55
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
This is also a good example.
Unread 09-01-2016, 21:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think the bigger issue with swerve is not the size of the wheels, but ensuring proper wheel and frame alignment with the obstacles.
Unread 09-01-2016, 22:01
FRC #1658
3 point swerve then it's not as big of an issue =p actually we plan to use field locked orientation with IMU which should ensure our wheels are always properly lined up for obstacles with temporary override to fetch boulders
