Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 09-01-2016, 20:14
3a11 3a11 is offline
FRC #0217
3a11 is an unknown quantity at this point
Large Discrepancy in Field Measurements
The first discrepancy we have found is in the given dimensions of the PLATFORMS. All references to the PLATFORMS (specifically section 2.2.2.1) in the Game Manual show them to be 4'2" in width. All field drawings show these platforms to be 4' exactly, leaving a 2 inch discrepancy. Another minor issue with the drawing of the PLATFORM in section 2.2.2.1 is that it lists the angle of the ramps to be 13.4 degrees whereas it should be 14.5 degrees (as the arcsin of 3 in/12 in is 14.5). I assume the correct width is 4' exactly as that is the standard size for plywood, but I'm not sure.
The really big discrepancy we have found is in the width of the field. In section 2.2 of the Game Manual, the field is listed as 26 feet 7 inches across (bound by the GUARDRAILS). According to the drawings, this 26'7" width of the field is spanned completely by the 5 DEFENSES (one Low Bar, 3 ALLIANCE selected, and one audience selected) of the OUTER WORKS, along with the SECRET PASSAGE. As referenced above the DEFENSES are either 4' or 4'2" in width (meaning all five cover either 20' or 20'10"). According to section 2.2.2.2, the SECRET PASSAGE is 4'5.5" wide including the berms. Finally, the 5 Shields are 3/8" thick, which adds 1.875". Now adding all of this up, we get the width of the field to be either 24'7.375" or 25'5.375". Either way this is significantly shorter than the 26'7" width of the field.
My question is, where does this discrepancy arise? Have we made some serious mistake in calculations? I apologize if this has been pointed out already. Thank you!
Unread 09-01-2016, 20:25
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: Large Discrepancy in Field Measurements
Noticed the same thing about the angles and when you layout the field elements the way they show them in the competition field drawings you get 14.5 degrees.
As far as field element width, look at the drawing for GE-16021 in the field drawings that adds 2.5" to either side of the shield so they are actually taking up 2.875" per shield or 14.375" total.
Still working through it, I'll update once I figure it all out.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 09-01-2016, 20:28
FRC #0217
Thank you! Felt like I was going a little crazy for a minute haha
