Fastest way to score the Most points
Any ideas on what's the fastest way to score, some of my ideas are to get the 15 or 20 points in auto then avoid the defenses and go through the low bar score the boulder into the high goal and go get another boulder and repeat, same scenario but instead of high goal score into the low goal to save time? end game scale for 15 points.
Re: Fastest way to score the Most points
it would be 20 1 cross and 1 high goal auto points are tallied at the end of auto (this is how I remember it) so you can only score 1 cross and would not score the reach.
Reaching a defense you get 2 points, 10 points for crossing, 5 points for low goal, =17, or if high goal 22 points, unless if reaching only gives you points for reaching and staying there, which is unlikely to me
Section 3.1.3 outlines that once a robot has gained a crossing, no more points for crossing/reaching can be given in auto to that robot.
thanks for the clarity
#7
You can score 17 or 22 points if you do reach after you score the high goal and go back to the outerworks "REACH an act performed by a ROBOT, such that at the end of the AUTO period, any part of a ROBOT’S BUMPERS are within the opponent’s OUTER WORKS" |
#8
Fastest way I can envision....
Three Scaling Bots 45 Three Auto max bots (Cross, HG) 60 <Fastest way less than 15 secs Then Best HG scorer stays in position in opponents courtyard Low Specialty/HG bot that somehow bridges the Secret passage to Courtyard expanse like a "REPEATER"..... Can intake HP bowled Boulders and somehow force them under Low goal engineered to get bowled boulders and expel under low goal to High Shooter. So so far Castle is weakened by 3 in auto so 5 more bowled boulders (HP- Specialty- HIGH Shooter) will weaken it In the Meantime the Tank Bot/HG specialist works on destroying defenses. After Castle is Weakened the Specialty bot destroys the low goal Getting Breach Points in combo with at least three from Tank Bot All Three then Scale. Achieving Max score +4RP per game I'm convinced some team will find that specialty bot to allow a repeated bowl to a High Point shooter (Most efficient reliable supply of boulders at least three from HP and any scored on you)---this years modular ramp bot Last edited by Boltman : 12-01-2016 at 16:44. |
#10
All-in-all, the fastest way to score the most points, is to have all robots score 20 points, breach the defenses, score an unbelievable amount of High Goals, and have all robots scale the tower. If all 3 robots can score like our robot (1073) is predicted to, the alliance will score 25-30 High Goals on a good day.
#11
Easy. Follow the points.
#12
Let's clarify that you do not have to bring a boulder through a defense to weaken it.
#13
True, but while you're on that side you may as well drop a present into the tower--that's -1 strength to the tower, and +2 or +5 points to you.
#14
Since the REACH points are assessed at the end of autonomous, and the robot cannot go back to get REACH points after receiving the CROSS points, the net points are 15 or 20 in your scenario.
(emphasis mine) Quote:
We've also assessed that "IT'S A TRAP" may gain renewed infamy this year amongst all of the star wars fans... |
