Go to Post For me, FIRST is inspiration with a positive feedback loop - it just keeps getting better. I wonder where it will go from here... - petek [more]
Unread 10-01-2016, 00:17
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Getting Started with Sensors
Hi All
Is there a thread or information out on the web on how to get started with Sensors? It's not entirely clear from WPILIb what hardware to buy and how to integrate it into your java code. I am thinking we need a camera this year and an ultrasonic, but I am not clear on what to purchase and then what to do with it once I purchase it. (Yes I've read quite a bit on WPILib but it is very high level and lacks context)
Thanks for any help.
Unread 10-01-2016, 09:52
origamitaco origamitaco is offline
FRC #4328
origamitaco is an unknown quantity at this point
Originally Posted by Tparbotmail View Post
Hi All
https://wpilib.screenstepslive.com/s.../13809/c/88895
I took at the pages myself and some of them do not specify what specific type of hardware while some do. The ultrasonic page did have several models and information on them. As for the camera, FRC supports the Axis 206, Axis M1011 and Axis M1013.
Unread 10-01-2016, 10:00
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Getting Started with Sensors
First place to start is to decide what problem you're trying to solve. In many cases, that depends a lot on the particular mechanism you're using.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 10-01-2016, 11:23
FRC #3944
Primarily we want to use vision for targeting the castle.
Another use would be to send visual data back to the driver due to the obfuscation from the defenses.
Range Finding is another problem we want to solve. I found a LIDAR Lite V2 sensor (currently on Back order) that beams light. We would like to find a similar sensor to measure distance. Any thoughts on components for that type of solution?
I've found out that ultrasonic sensors are susceptible to noise interference so I don't want to use them now.
