Go to Post This is a game of the mind. Size does not matter. - JohnBoucher [more]
Unread 10-01-2016, 00:52
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Can you view the webcam from the TCP connection?
Hi,
I have been struggling to get the USB Camera to work with the RoboRIO for a long time. Now that I see that the new game has many obstacles that make it hard for the driver to see, I desperately want the camera to work. I was reading the Game Manual for this year and I saw under 2.4 Section this:
A. TCP 1180: Camera data from the roboRIO to the Driver Station (DS) when the camera is connected the roboRIO via USB, bi-directional.
So that got me wondering if I could do roboRIO-4480.local:1180 and see if the camera itself isn't working? Also, we have the Logitech C270, is the light supposed to turn green on the webcam when you turn on the robot? Our webcam doesn't(but it does when you use it on a computer).
Many thanks! Can't wait to start building the actual robot!
Unread 10-01-2016, 00:53
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Can you view the webcam from the TCP connection?
Originally Posted by team-4480 View Post
Hi,
In your robot code, you have to use the CameraServer class, which will stream the images from your camera to your driver station. The robot does not do this by default.
Team 4488 - Mentor 2013-2016
Unread 10-01-2016, 01:03
team-4480's Avatar
Debug? What's that?
FRC #4480
Yep, I should have added that I am currently using this code(It is in Python but it isn't any different then Java/C++)
        try:
            self.camera = wpilib.USBCamera()
            self.camera.startCapture()
            self.camServ = wpilib.CameraServer()
            self.camServ.startAutomaticCapture(self.camera)
        except:
            self.camera = None
I put this in the startup __init__ code.
Unread 10-01-2016, 09:23
Hi,
no, the protocol isn't http. Also note the men's name changed this year.
        try:
        except:
            self.camera = None
It isn't going to work if you don't implement the changes from your other thread http://www.chiefdelphi.com/forums/sh...mp;postcount=2
Unread 10-01-2016, 11:17
team-4480's Avatar
Debug? What's that?
FRC #4480
I did implement the changes in that thread, but I ended up with the same problem. Could it be that our webcam is not supported(Logitech C270)? Maybe next time I should try on a computer that has a Linux distro and see if it works there...
Unread 10-01-2016, 20:40
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
You might try removing the 'except:' to see if an error gets thrown. It may be instructive and explain what the problem is.
Or better yet:
try:
except Exception:
    self.logger.exception("Could not enable camera")
    self.camera = None
Unread 10-01-2016, 21:14
team-4480's Avatar
Debug? What's that?
FRC #4480
Or better yet:
try:
except Exception:
    self.camera = None
Ah yes! Would that statement show up on the Driver Station then? Or would it be a "py robot.py deploy --nc" thing? Thanks!
Unread 10-01-2016, 21:19
virtuald's Avatar
RobotPy Guy
Netconsole, so using --nc
Unread 10-01-2016, 21:24
team-4480's Avatar
Debug? What's that?
FRC #4480
Awesome, now I will finally know for certain what is happening! Thanks!
Unread 10-01-2016, 22:40
virtuald's Avatar
RobotPy Guy
I just tried out the USBCamera class RobotPy 2016.0.0 with the default LabVIEW dashboard, and it doesn't work. Looking at tcpdump, the RoboRIO seems to be rejecting the incoming connections for some reason.
I'll debug this for a little bit, but honestly as I've said before the CameraServer stuff in python is *really* terrible, and if I can't get it to work relatively quickly then I'll probably remove it from the next release.
Unread 11-01-2016, 00:57
virtuald's Avatar
RobotPy Guy
Well, one possibility is that you don't have pynivision installed. I didn't have it installed, and there was no way to know that it was using the 'dummy camera' instead of the real camera.
When I install pynivision, I get a "Connection reset by peer" error. The problem is that when the LabVIEW dashboard connects to the server and it encounters the wrong version of networktables (we haven't upgraded to 3.0 yet), it disconnects from the camera. When I block the NetworkTables connection, then the camera works fine.
It's pretty terrible, the CPU usage is at 51% without the robot code actually doing anything (as compared to ~7% without the camera code). I wouldn't recommend using it, and I suspect we'll remove the camera stuff from the next release.
I'm tracking this issue here: https://github.com/robotpy/robotpy-wpilib/issues/172
Unread 13-01-2016, 11:10
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Originally Posted by jijiglobe View Post
Just a fair warning from a New York team. Some regionals have extreme bandwidth issues (New York being one of the most extreme examples). One year(I think 2014) a lot of teams did exactly what you described (using a camera to stream to the driver station) and it created huge amounts of field lag. The event staff had to force everyone to turn off their camera streaming. Probably not relevant to most regionals but if you're reading this thread, it's probably a good idea to talk to other teams at your regional to see if this issue has happened before. If so, it's best not to rely on the camera feed.
I remember this it was rough to say the least.
The Javits center really needs to start being more accommodating they know it's a not for profit holding an extremely expensive event. Last year there were similarly sized halls empty at the time so it's not like it was going to get rented out by someone else.
