Go to Post They could release an update saying they were going to give every team free puppies and kittens, and many teams would vehemently complain this change was too late to budget dry kibbles into their budget. - artdutra04 [more]
Unread 11-01-2016, 13:11
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
Use FTC control system to test FRC drivetrain?
Please pardon my ignorance if this question is stupid:
Could one use the FTC control system (android phones, Modern Robotics motor controllers) to test out an FRC drivetrain? I was just toying with the idea in my head, and wasn't sure if it was possible. So this is a thought exercise. I don't trust the new FTC control system enough, yet, to use it on a larger robot that can turn into a runaway. Plus, those USB connections. But, anyway:
It seems like you would just plug in the CIM motors to the MR controller, and it should work, right? They are both 12V.
Or maybe not: Stall Current on the NeverRest 40's (FTC motors) is 11.5 Amps while it's 133 Amps on the CIM motor. MR Controller (http://www.modernroboticsinc.com/cor...r-controller-3) says max 5 Amps per motor. CIM says it's 2.7 Amp "Free Current". I am not sure how to interpret this. Does that mean you'd be okay unless you stall a motor?
Bottom line: what are the odds of frying an MR controller if you hook it up to a CIM-driven drivetrain?
Unread 11-01-2016, 13:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Use FTC control system to test FRC drivetrain?
You can connect an FTC battery with PowerPoles directly to a motor with PowerPoles if you need to test a motor quickly, but I suspect you will not have a good day if you try to run a whole FRC robot off of the FTC control system (for the reasons you already suspect).
