Is anybody talking about the low bar?
We've been curious as to what some other teams are considering going for the low bar. We've talked about some of the design constraints and decided that it is super dependent on other robots. So what are you guys thinking? Is it worth it to go for the low bar if no one else is?
Re: Is anybody talking about the low bar?
If you actually looked at Chief Delphi before posting you would know there already has been countless posts about this in the last 2 days.
Sorry for the saltiness but it really annoys me as it disrupts discussion. |
If you don't like the thread, either ignore the thread or graciously send a PM explaining why it is important to do a search and also why it is important to read the sticky threads about basic posting etiquette. If you're gonna respond to a redundant thread, answer the question or direct the OP to the thread where they can find the answers. If you really gotta tell them what they're doing wrong, leave that as a private message so you're not calling them out publically. It's this kind of tactless impatience with new members that can drive people away from this forum. |
Our team is thinking of just not doing the low bar because of the restraints involved with having a robot that could fit under the low bar.
#7
Our team has personally made the decision to go for the low bar, as it provides an easy way of scoring during autonomous and is a simple defense to overcome (as long as you meet the height limit). There will likely be many teams that are going for the low goal, though, and I can see why you would be debating the pros and cons.
At the end of the day, this decision is up to you and your team. You could easily find a way to score points either way. |
#8
One potential option to consider is using a detachable mechanism. Low bar capable when the alliance strategy determines it.
#9
Dynamic robots by match would be interesting this year. Not necessarily for changing based on the selected defenses (however you should know which defense was selected by the audience before queuing for a match) but maybe based on what your alliance can do. |
#10
Hey SOTA,
We skipped it, there is a whole thread on the idea, (as you have seen) which was a surprise to me at first. Identify what you wish to do strategy-wise, then make a way to pass under the bar. FRC 4579 RoboEagles |
#12
Our team discussed this option, and found many flaws involved, I'd encourage you and your team to careful weigh how many benefits are had by doing this, and what are they. Just an idea, because it could prove an amazing design, or it could prove fatal to your robot during the season. Best of luck from T3!
#13
Our answer was YES, we need to be able to cross under the low bar. It's there every match, in the same location. It's ESSENTIAL for teams going after lots of boulder points (which is the only "unlimited" source of points), and still pretty important for teams playing for a sapper (focused on breaching defenses) function. I think most top 8 and first-pick alliances will fall into one or both of these two categories.
I would not be surprised if our initial configuration is more than 14-16" tall, but I absolutely expect us to have a configuration that will fit below the low bar while carrying a boulder. |
#14
Where's the rule that your boulder has to pass through under the Low Bar just because your robot must? My idea alone (you'd need to check w/ the rule makers so you wouldn't be a rule breaker). As long as the robot maintained full control over the boulder during the entire traversing from beginning to end.....Long narrow low robot under the 120" frame limit, boulder gripper on the rear, boulder gripper on the front......Robot begins to pass under Low Bar and the drape and pole at bottom of drape, the rear gripper passes boulder to front gripper over the top bar of the Low Bar when about half way through, deposit in low goal or deliver to high goal shooter. As soon as the wheels hit the carpet completely (if there was a high goal shooter), it would be easy to pitch pass it to the shooter....zoom back for more ammunition. The Robot never lost control of the boulder, and robot never went completely over the Low Bar as per the rule. Asked properly of the Q&A the answer may just surprise many of us. Three fingered simple ball grippers front one rotated 1/3 so the fingers fit together. Adjustable pneumatic. |
#15
Edit: We did not consider handing the boulder to ourselves, over the bar, but we may carry it outside the frame perimeter for the low bar crossing. We like simpler. Last edited by GeeTwo : 13-01-2016 at 07:16. |
