Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Unread 14-01-2016, 14:35
fruitcup fruitcup is offline
FRC #5212
fruitcup is an unknown quantity at this point
CIM motor maximum speed & torque?
Hi. I'm a little confused on what a CIM motor's maximum specs are within the context of FRC.
According to the Vex website, CIMs have a stall torque of 340 oz-in and a stall current of 133A. Because our CIMs are attached to 40A breakers, I believe that our motors won't be able to reach the 340 oz-in limit.
How can I calculate what the maximum torque of a CIM is without tripping the 40A breaker?
Thanks, I would appreciate any guidance.
Unread 14-01-2016, 14:38
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: CIM motor maximum speed & torque?
From what I understand about the breakers, you can briefly exceed the 40A limit without tripping them. This has to be the case, because otherwise every time a team got in a pushing match where their CIMs experienced near-stall currents they would be tripping breakers instantly.
Edit: some quick research has illuminated the problem for me. The snap-action breakers are thermal breakers. This means that they trip when they reach a certain temperature, rather than the instant they hit a certain current. That's why you can stall your drivetrain for brief moments without tripping them. They also include an electromagnetic component that will trip instantly when subject to major surges, like what you would see from a short circuit.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 14-01-2016, 14:50
Knufire Knufire is offline
What Joesph said. See the current vs tripping time graph here: http://files.andymark.com/MX5SpecSheet.pdf
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-01-2016, 15:30
FRC #5212
That is very good to know. Thank you both!
Unread 22-01-2016, 02:00
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Don't forget that you have a 120A breaker on the entire robot. That limits the current draw in addition to the 40A breakers, especially as the number of motors increase.
Unread 22-01-2016, 08:36
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Behind the Design has a good documentary on the relationship of torque on the motor and the current it draws.
http://frcdesigns.com/2013/06/24/beh...earbox-design/
With a CIM having:
a free spin of 5310 RPM
free current draw of: 2.7 A
Stall Torque of: 343.4 oz-in
and Stall current of 133 A
You can work the equations listed in the document for how much torque would be available for 20A (or another number, that's just what my team has used), and use that torque and a gear ratio to find available torque at the wheels when only pulling 20A. If you can move at this current, use the gear ratio again to determine what torque at the wheels would stall the motors (this can be combined with the wheel size to get a max pushing for - ignoring weight of the robot).
I wrote a python script that can calculate the gear ratio to move a desired speed and the minimum number of motors to move at that gear ratio assuming a coefficient of static friction of 1 (static friction must be overcome to get the robot moving). I can post it if desired.
