Go to Post Repeat after me: "The Internet is my friend." :rolleyes: - Bill Moore [more]
Unread 16-01-2016, 15:18
Brian Michell's Avatar
Brian Michell Brian Michell is offline
Timelord and programmer
FRC #5416 (TaRDIS)
Rookie Year: 2015
Brian Michell is an unknown quantity at this point
Defense robot idea
Our team is thinking about ways to be a defending robot and we thought about using a large fan that we could use to blow flying boulders off its intended trajectory.
Is this legal? We have found no rule outlawing it, but we are not sure. Is this something we should be asking on the Q&A section?
Unread 16-01-2016, 15:19
Re: Defense robot idea
There are no rules prohibiting it. However, you'll need to be careful about safety.
Also, there have been studies in the past that indicate that it probably won't be as effective as you might think.
Unread 16-01-2016, 15:28
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Because a week of your build season has gone by already, and at this point teams really shouldn't waste time on a dead idea. I'll go beyond what EricH wrote.
You won't be able to blow flying boulders off course. While it might be theoretically possible in near-perfect circumstances to deflect them a tiny, but measurable, amount, it is a wholly impractical defensive method.
Doing the experiments,etc for this is valuable (in off-season?); but probably less valuable (right now) than investing your time in properly developing a design that is much more likely to pay off.
Blake
Unread 16-01-2016, 16:28
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
this was attempted a few times in 2012 (I think 492 was one of those teams that tried it). never really did much. and these balls are heavier.
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 16-01-2016, 19:34
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
In theory you could make a fan with a legal motor. However, the rules do not seem to contemplate that (only considered fans with built in motors), and would would have to comply with any rule specific to fans.
Unread 16-01-2016, 19:41
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
There's nothing saying you can't take 4 of your 6 allotted CIMS, stick them in a custom gearbox, attach it to a fan blade, put the entire thing in a safe enclosure, and go of on your marry way to your first match. Where you would probably then discover that the ball isn't going to be particularly persuaded to alter its course.
Do with the information in this thread as you will, but the suggestion would be get your hands on an industrial fan, point it upwards, and then throw a ball through the stream.
Academic Student (Forever)
