Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 16-01-2016, 21:48
JohnRLewis JohnRLewis is offline
FRC #1294 (TopGun)
Rookie Year: 2015
JohnRLewis is an unknown quantity at this point
Has anybody gotten NetworkTables to work on a RaspberryPi
I'm trying to get NetworkTables to work on a RaspberryPi. But the native libraries do not work. The NetworkTables-3.0.0-SNAPSHOT-arm.jar file contains a Linux.arm libntcore.so, but it will not load:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/pi/libntcore.so: /home/pi/libntcore.so: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1929)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1814)
at java.lang.Runtime.load0(Runtime.java:809)
at java.lang.System.load(System.java:1083)
at org.usfirst.frc.team1294.vision.Application.main(A pplication.java:80)
Which pretty much means that the native binary was compiled for the architecture of the RoboRio, and is not compatible with the RaspberryPi.
I tried getting the NetworkTables source to compile on the RPi. But was getting too many errors that I did not understand.
Has anyone gotten NetworkTables to work on a RaspberryPi?
Unread 16-01-2016, 21:57
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Has anybody gotten NetworkTables to work on a RaspberryPi
I am working on setting up a build server for a Raspberry Pi 2 build. It can be found here. http://198.199.94.5/ntcore/. Use the latest/arm-linux-gnueabihf/ binaries. Note this will only work with Pi 2's. Pi 1's are much harder to get working with.
Note to use this, you will need to grab the libstdc++.so.6, and set LD_LIBRARY_PATH to include the path that file is in before running your program. I have not actually tested this on a Pi 2, however I did test it on a BeagleBone Black and a CHIP and it worked on both. I will test the Pi 2 tonight.
The reason the RoboRIO libraries do not work is that the RoboRIO is Arm vfp, whereas Raspberry Pis and BeagleBone Blacks are Arm Hard Float.
Team 4488 - Mentor 2013-2016
Unread 17-01-2016, 00:19
FRC #1294 (TopGun)
Rookie Year: 2015
I gave your .so a try, but get the exact same error.
Unread 17-01-2016, 00:32
If you are using Java, try the jar in the Java folder instead of the maven jar. That should have the ntcore library built in and automatically extract it.
If that doesn't work, when you try and run the project, there should be a line that gets printed that starts with "Platform:". What does that string say?
Looking at the source code again, it does look like you should just be able to put libntcore.so in /home/pi/. Does that work?
Unread 17-01-2016, 11:14
FRC #1294 (TopGun)
Rookie Year: 2015
I created a new super simple java app to rule out anything else. I did not add any dependencies to NetworkTables. Inside my main method, I have a single line:
System.loadLibrary("ntcore");
I thought I was getting the identical error, on closer inspection, I am getting the following now:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/pi/libntcore.so: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /home/pi/libntcore.so)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1847)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1119)
at org.usfirst.frc.team1294.vision.Application.main(A pplication.java:14)
Unread 17-01-2016, 12:51
Ah. So to fix that, you need to download the libstdc++.so.6 in the ntcore folder. Place that in /home/pi/ on your Pi, and add this line to your program start command.
env LD_PRELOAD=/home/pi/libstdc++.so.6 . So your command to run would become env LD_PRELOAD=/home/pi/libstdc++.so.6 java myapp.jar, replacing myapp.jar with whatever your app is.
Unread 17-01-2016, 17:19
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Is the native library necessary for NetworkTables to execute?
Previous year's network table JAR did not contain native libraries. My latest copy of the jar contains an *.so file for Linux ARM, but none for any other operating systems or architectures.
Can we simply ignore this file? Or, can we just remove the native library from the JAR before deploying to a Raspberry Pi?
Unread 17-01-2016, 17:22
FRC #1294 (TopGun)
Rookie Year: 2015
Same error.
When I run the following:
strings /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 | grep CXXABI
I get:
CXXABI_1.3
CXXABI_1.3.1
CXXABI_1.3.2
CXXABI_1.3.3
CXXABI_1.3.4
CXXABI_1.3.5
CXXABI_1.3.6
CXXABI_1.3.7
CXXABI_1.3.8
CXXABI_TM_1
CXXABI_ARM_1.3.3
which is missing the 1.3.9 that the error message is asking for.
Is CXXABI_1.3.9 a requirement? Or would it compile against 1.3.8?
Unread 17-01-2016, 18:57
Same error.
I get:
CXXABI_1.3
CXXABI_1.3.1
CXXABI_1.3.2
CXXABI_1.3.3
CXXABI_1.3.4
CXXABI_1.3.5
CXXABI_1.3.6
CXXABI_1.3.7
CXXABI_1.3.8
CXXABI_TM_1
CXXABI_ARM_1.3.3
So for some reason its not accepting the LD_PRELOAD paramter. Will you send me your JAR so I can test? It's working for me.
So I just tested it again, and got it to work completely. Are you sure you're setting LD_PRELOAD correctly?
Unread 18-01-2016, 08:52
FRC #1294 (TopGun)
Rookie Year: 2015
Here is my jar, but I suspect that it is going to work for you too.
https://github.com/JohnRudolfLewis/n...ntcoreblah.jar
I believe there is a difference between our environments. On your Pi, when you run ldd libntcore.so, how does your output differ from mine below?
pi@raspberrypi:~ $ ldd libntcore.so
./libntcore.so: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./libntcore.so)
./libntcore.so: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./libntcore.so)
linux-vdso.so.1 (0x7eded000)
/usr/lib/arm-linux-gnueabihf/libarmmem.so (0x76f6d000)
libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76e7a000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76e4d000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76d10000)
/lib/ld-linux-armhf.so.3 (0x54aef000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x76c95000)
Unread 18-01-2016, 10:36
I get the same output too. Thats why you have to call LD_PRELOAD before you run your program. LD_PRELOAD allows you to specify a different library as the dependency. So if you LD_PRELOAD to the libstdc++.so.6 found here http://198.199.94.5/ntcore/libstdc++.so.6 it will load that one before trying to load the default one and should work.
Unread 18-01-2016, 12:18
FRC #1294 (TopGun)
Rookie Year: 2015
I believe I am following your instructions properly, this is the command I am running to launch my jar:
env LD_PRELOAD=/home/pi/libstdc++.so.6 java -jar ntcoreblah.jar
But I still get the error. Is my syntax wrong? Is there yet another dependency that I need to preload? Is there something I need to install on my Pi in order for that environment variable to take effect?
Thank you so much for continuing to reply and not giving up on me!
Unread 17-01-2016, 17:47
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
It's absolutely necessary: this year, networktables is implemented as a native library. We use jni to talk to it from Java.
Unread 17-01-2016, 17:48
WPILib Developer
FRC #0190
Same error.
I get:
CXXABI_1.3
CXXABI_1.3.1
CXXABI_1.3.2
CXXABI_1.3.3
CXXABI_1.3.4
CXXABI_1.3.5
CXXABI_1.3.6
CXXABI_1.3.7
CXXABI_1.3.8
CXXABI_TM_1
CXXABI_ARM_1.3.3
It should compile against 1.3.8, but we do not distribute versions that link against those library version.
