Go to Post I wonder if the GDC had his extraordinary achievements in mind for the 2012 game. - MagiChau [more]
Unread 18-01-2016, 18:13
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
pic: Harbor Freight 8 inch tire on 3d printed hub
Unread 18-01-2016, 18:14
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: Harbor Freight 8 inch tire on 3d printed hub
Have you tested the strength of the wheels yet? Our 3D printed parts usually hold up pretty well if there isn't much shearing force. If someone hits you from the side, you might get quite a lot of that.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 18-01-2016, 18:15
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Did you design the hub or use a previously created file?
Also, could you post the CAD file?
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 18-01-2016, 18:50
So far it feels pretty strong, we'll test a bit more when the rest of our belts come in. My hope is that most of the load will be taken in the tire and soften the blow to the wheel itself.
I wasn't a huge fan of the look of the hubs from AndyMark so we designed our own but used some of their proven geometry to interface with pulleys and sprockets. There were probably more efficient designs, but these look good.
I'll post CAD soon, but I would want to make some changes first. The wheel is a tight squeeze in the tire and requires a bit of coaxing to get it together. All in all it turned out okay though.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 18-01-2016, 18:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are the tubes/tires from those actually 8", or are they 200x50mm?
Unread 18-01-2016, 19:01
The are actually a little bigger than 8" when aired up. I think they were around 8.75 all said and done. The tire size is determined by the hub and measures 2.50-4 on these.
Andrew Basse
Unread 18-01-2016, 20:50
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Hey neighbor... How much for you to print us up some hubs? We're striking out getting 8" wheels - everything is sold out. We looked at the HFT wheels but they were so heavy with the steel hubs.
Unread 18-01-2016, 20:58
SamM SamM is offline
FRC #5842 (Royal Robotics)
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Nice!
It's important to note that the Harbor Freight tires will not work with the stock Andy Mark Hubs anyway, and it can be a bit dangerous to try.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 18-01-2016, 21:12
The cost isn't the big part... it's the time. 33 hours for each side of the robot. 66 hours is a loooooooooot of printing.
If you really want to we probably could do it, it's at least double the price of Andymark. Wouldnt you know it, once i hit print on the second set, AM hubs came back in stock. I'd have to do math to figure the numbers out for you and I'm nowhere near ready to be in a BOM mood yet...
I'll put a kid on it tomorrow and run the numbers for you though.
Andrew Basse
Unread 18-01-2016, 21:36
pribusin's Avatar
Uber Alien
AKA: Mike 1
Andy, will the AM hubs fit the HFT wheels close enough to use?? Did you try them?
Unread 18-01-2016, 21:51
They fit very very loose. The hubs spin inside the tire. You might be able to add material to the hubs, but I would have little faith in running the AM hubs with a non 200x50 tire. I think Airway Oxygen carries wheelchair tires though.
Andrew Basse
Unread 18-01-2016, 22:20
When inflated the HF tire bead will push past the wheel.
We sliced the HF hubs up to make adapter rings that fit over the AM hubs. They fit surprisingly well.
Unread 20-01-2016, 15:34
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Any update on the CAD of this wheel, and how they've been working for you?
We have some solid printing abilities, and if this saves weight we're definitely interested in trying a few out.
Also: How much filament is each wheel?
Unread 20-01-2016, 15:48
andrew4130's Avatar
andrew4130 andrew4130 is offline
4130 Controls lead
AKA: Andrew Caporuscio
FRC #4130 (The Blue Devils)
Team Role: Electrical
andrew4130 can only hope to improve
http://www.thingiverse.com/thing:1275569
Here you can download the .stl file of the hub!!!
Unread 20-01-2016, 19:20
If anyone is interested, I updated my file and will post a Thingiverse link tomorrow. They seem to hold up okay, but we haven't aggressively tested yet. That won't be done until next week, unfortunately.
Andrew Basse
