Go to Post I firmly believe that - those [GDC] committee members I have met, even briefly, certainly have a passion for what they are doing and want to give teams and students the best possible experiences. - GaryVoshol [more]
Unread 21-01-2016, 04:04
simon1636 simon1636 is offline
FRC #4501
simon1636 is an unknown quantity at this point
Two Talons for Two Sets of Wheels
Hi! My team's robot has two sets of 3 wheels on each side. It's 6 in all. The left side is hooked up to a talon as well as the right. We are trying to get each game pad joystick to run each side seperately. In order to do this, would you assign each stick a talon, and have it so that when that joystick is pushed, the talons speed is set to a number? This is what I thought, but if anyone can show some sample code of our desired outcome, that would be great! Thank you guys so much!
Unread 21-01-2016, 07:12
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Two Talons for Two Sets of Wheels
Check out the Tank Drive class. When you go to create a project in eclipse, instead of clicking Robot Java Project, click "Example Robot Java Project" and find tank drive in the list.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 21-01-2016, 10:57
BenD BenD is offline
FRC #4828 (Swift Creek RoboEagles)
BenD is an unknown quantity at this point
After defining your Talons and Joystick objects in your Robot class, create a RobotDrive object like so:
RobotDrive drive = new RobotDrive(leftTalon, rightTalon);
Then simply call the tank drive function on your RobotDrive object:
drive.tankDrive(leftJoystick, rightJoystick);
