GRIP deploy: bash: /bin/java: No such file or directory
The title pretty much states the problem. When we try and deploy a GRIP program to the roborio, we get the error: bash: /bin/java: No such file or directory, and the loading bar says "Running GRIP" We cannot seem to find a solution to this problem, or anyone else who has had it. Any help is appreciated! Thanks!
Re: GRIP deploy: bash: /bin/java: No such file or directory
We have followed the screen steps tutorial previously, and I just did it again to be sure, but it still is not working. Thanks for your quick response!
Well that is exactly what the error is saying... Does that folder / files in the folder exist if you connect to them via filezilla?
Bin exists, java does not. Is there another way we could try to install java instead of the screen steps way?
I'm pretty sure all the installer does is ssh over the linux installer for Java then runs it... you could try doing that manually. Just be sure to get the right distro that it tells you to get in screensteps
#7
Go to your project settings and make sure Deploy Java Home is set to "/usr/local/frc/JRE". It should be by default, but it could have gotten changed
